-   -   What mods are on your car? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/796255-what-mods-your-car.html)
speednme1 02-11-2014 02:45 PM
So this winter blows....and I'm bored...so I decided to tally up(not cost of course:D) the several mods on my car...also wondering what others have done...so post them if you got them...hopefully the purist won't cringe...here goes!
Ruf wheels
Ruf front spoiler
Ruf front oil cooler
Ruf 5 speed tranny
Ruf intercooler
Ruf muffler
Ruf boost controller
Ruf mirrors
Ruf steering wheel
Motor be Dawe's Motorsport
3.4 liters P&C
Twin plug heads/injection
Garret GT35 ball bearing turbo
Ghl headers
Custom camshafts
Tial 50mm bov
Tial waste gate
Motec M84 ecu
Motec wideband with Motec display
Trg coilovers
Rebel Racing 935 spring plate assembly
Rebel Racing rear bearings
Elephant Racing GT3 complete front suspension
Smart Racing sway bars
DZug front cross strut brace
DZug hid front lamps
Heigo roll bar powder coated wrinkle finish
Custom Recaro LS seats
Mcintosh head unit
Mcintosh amp
Focal speakers with crossover
Hawk brake pads
Etarga led gauge light bulbs
New windshield (old one was pitted)
Rennshift shifter
Wevo tranny mounts
Wevo engine mounts
Andial gauges
jwasbury 02-11-2014 03:14 PM
So a new windshield is now considered a modification?
Just busting yer balls Rey...:p
jwasbury 02-11-2014 03:23 PM
This winter is killing me too. To help with the seasonal depression, I watch this video: Me flogging the 911 race car around Monticello full course.
Spec911 Monticello full course lap HD - YouTube
OldSpool87 02-11-2014 03:33 PM
The best part about that video is you (I assume) adjusting the camera at 125mph! Looks like a nice track layout.
nickyclyde 02-11-2014 03:36 PM
Awesome video!!!
speednme1 02-11-2014 03:52 PM
My bad..forgot that I put that in there:)
speednme1 02-11-2014 03:53 PM
How's the track car working out for you? I'm sure you can't wait for the good weather to roll in....
Jeff NJ 02-11-2014 04:02 PM
So I've had my car for 2 months and only put 200 miles on it with the ridiculous winter going on here, so this is what is modded. I bought it this way and haven't done any mods myself yet. Don't laugh.
Momo Steering wheel.
930 door sills.
kenwood radio.
pedal set.
shift knob.
I have all the original parts in boxes.
I think I get like 40 extra HP with all these mods combined, right? Anybody dyno'd a radio upgrade? :D
I want to drive it stock for a bit and then I'm sure to start putting on the bolt ons... headers, turbo, 1 bar spring, adj WUR, etc. I am sure I will be coming here for advice as to what to do first and so on...
Robbbyg 02-11-2014 04:07 PM
Heres one of my FREE custom mods
A shark head i carved into my muffler holder with an angle grinder complete with handpainted flames...http://forums.pelicanparts.com/support/smileys/pyth.gif
http://forums.pelicanparts.com/uploa...1392163591.jpg
Robbbyg 02-11-2014 04:10 PM
930 door sills.
kenwood radio.
pedal set.
shift knob.
Weight saving from stock to modern radio will see improvement in 0-100 times:cool:
Ronnie's.930 02-11-2014 04:13 PM
I think Mark has us all whipped with regard to modifications - entire car heat treatment! :D
Jeff NJ 02-11-2014 04:15 PM
Awesome! But since I literally can't get it out of my garage with the layers of ice on the driveway and another 10-12" of snow coming Thursday, it may be April before I can test out your assertion.:(
aschen 02-11-2014 04:17 PM
rarely l8 muffler, aftermarket head unit, 935 boost gauge, and recently completed Kuel AC system.
Otherwise bone stock down to the 3dlz (or however you call it).
I do have a wideband on my shelf I have been planning to install for several years.
quattrorunner 02-11-2014 04:47 PM
Dry film lubricated/thermal barrier/powercoated internals.
sc cams
headers
no cat
magnaflow
Andial intercooler
Snow WMI
Garrett GT30r turbo
Fikse 17inch
Dual oil coolers up front
Elephant racing oil finned lines and fittings
NHS Boost gauge in clock location
Innovate AFR
Innovate EGT
Stereo system
Illest sticker (small)
turbokraft sticker (tiny)
And last but not least.........
911 vin chassis
jwasbury 02-11-2014 05:01 PM
Rey - the track car is awesome. love it. can't wait to drive it again. have spent a little time fine tuning the EFI (motec) because it was not idling worth crap. so now i'm a tuner - yo!
OldSpool - yes that was me adjusting the camera:eek: not the smartest move I realize, but I wanted a good vid for my homies here on the forums. that damn lexan windshield shakes a bunch at terminal velocity, and the iphone mount can't hold position. I'll be back next season with a proper camera/video overlay system. No more harrys lap timer for me.
Mods on the 930 from front to back:
yellow fog lenses
front mount oil cooler
modified factory valence to fit FMOC
H1 Headlamp assemblies
38 tube brass "Euro" fender oil cooler
Fikse FM5 18x9 front wheels
weltmeister strut brace
bilstien sport front strut inserts
sanders hollow front torsion bars
Elephant Polybronze control arm bushings
Elephant low friction control arm mounts
ER bump steer kit
Crappy Blaupunkt CD stereo unit
Innovate G2 Analog AFR guage and VDO voltmeter mounted in ashtray location
Innovate DL-32 datalogger
Wevo shifter
Recaro Sportster CS seats
Schroth 4 point ASM harnesses
Stable Energies Harness guide bar
Halotron Fire Extinguisher in Brey Krause billet mount
Elephant trailing arm monoballs
Elephant Polybronze spring plate bushings
Sway Away hollow rear torsion bars
Elephant rear cambermax adjusters
Fiske FM5 18x11 rear wheels
bilstien sport rear struts
Hargett Lower valve covers
Electromotive XDI2 Twin plug ignition system
SC cam grind
Racing valve springs
Titanium retainers
Intakes ported to 37mm
Port matched manifold
Billet injector blocks
Crank shaft cross drilled for increased oil supply to #2 & #5 rod journals
ARP rod bolts
ARP headstuds
JE 7.5/1 CR pistons
LN Engineering Nickies Cylinders 100mm - 3.5 liter displacement
SSI heat exhangers w/ crossover pipe by Rarly L8
Rarly L8 stock-exit muffler
K27S turbo
Kokeln Intercooler
Euro taillight lenses
Pelican license plate frame
DSPTurtle 02-11-2014 05:43 PM
Where do you get a Pelican license plate frame?
speednme1 02-11-2014 05:56 PM
Pelican Parts - Product Information: PEL-PLATE
cdill 02-11-2014 08:07 PM
In order of what broke 1st and I decide to replace it with something better.
G50
Wevo shifter
K27
Adjustable WUR
Lindsey 17x8 & 17x11 (tires needed replaced on the BBS RS that came with the car)
Alpine head unit
Tippy 02-11-2014 08:16 PM
You broke a G50?
cdill 02-11-2014 08:17 PM
You broke a G50?
No I broke a 4 speed installed a G50 (supposed I should have stated my car is an 84)
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
