Scout012's Avatar
CIS Brass fuel inlet Hollow bolt FILTER
WHERE can I find these??????? tiny removable plastic fuel filter screen in the brass fuel inlet fitting on some fuel heads
there are barely any references to them and I am wondering if i should just remove them. mine are bent up from prior removal (not me of course) and two were stacked in one fuel line bending the filter and destroying it.
Any help appreciated.
The final Picture is one off of my CIS bolt.
(1980 930 stock CIS)
KEN Euro '80 930
Old 02-18-2014, 12:24 PM
My fuel head didn't have one of those originally and when I got my fuel head back from CIS Flowtech from being modified and rebuilt it had one inside a new brass fitting.
That's a really small fine screen filter and it looked like it could impede flow at full throttle and lean out the motor under full boost so I pulled it out of there with needle nose pliers and tossed it.
You don't need it if you have a 930 Mahle fuel filter next to the accumulator. The Mahle filter has a finer micron element thats huge compared to that little tiny screen filter
You could probably get one from Larry at CIS Flowtech in Alabama.
Old 02-18-2014, 02:37 PM
proffighter's Avatar
check a Mikuni carburetor dealer (motorcycle), looks similar to me like some of the filter in the in-line of the carbs sometimes have. Diameter is maybe 5mm
Roland
930 Turbo '81 Too many modifications to list
Old 02-18-2014, 03:44 PM
