Smart quod bastardus
fredmeister's Avatar
SSI heat exchangers on 930
What needs to be modified to adapt SSI heat exchangers to the 930?
I know the crossover pipes to the turbo need to be custom but doesn't RarlyL8 sell this special turbo crossover plumbing?
Any special gaskets or flange mods to the SSI and which version SSI works best?
Thanks,
Fredmeister
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 02-18-2014, 02:16 PM
I've gone native
Tt surgeon's Avatar
You need to backdate the oil lines as well, crossover and pickup line to the t stat.
Keep in mind that the pipe dia is smaller as well.
Old 02-18-2014, 02:45 PM
gumba's Avatar
SSI use to offer a 930 version, did they discontinue it? I bought one of the earliest sets.
Harold
'79 930/DP935
'68 VW Turbo Crewcab
Old 02-18-2014, 03:57 PM
beancounter
jwasbury's Avatar
I bought the SSI kit from Bryan some years back. It has the same exchangers as Gumba's, that terminate with vband flanges just after the merge. I believe they came that way from SSI. Bryan's part was the crossover pipe and turbo inlets, wastegate plumbing, etc. I notice that the turbo flange on my set up is also stamped as SSI, but I seem to believe Bryan's crossover was his design and welded up by his supplier, not SSI. Fred will not need to backdate oil lines if he still has the original set up on his '79. '79 models came 'backdated' from the factory.
Look closely and you can see SSI stamped into the cast (or is it forged) bit where the x-over meets the turbine inlet
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 02-18-2014, 04:11 PM
I've gone native
Tt surgeon's Avatar
Probably the coolest exhaust you could put on a 930!
Old 02-18-2014, 05:53 PM
Crotchety Old Bastard
RarlyL8's Avatar
We designed a couple versions of the secondary pipe assembly, one elephant nose and one with dual waste gates. Nice system. The only thing I didn't like about it was the length of the secondaries. Really no way to get around that.
The best SSIs to used were the ones designed for the 930. They were 321 stainless and came with v-band flanges.
When using standard 911 SSIs we put a slip joint on the secondaries and you simply cut the SSIs after the collector. You'll notice we got away from the heavy cast SSI y-pipe and made our own merge collector.
Old 02-18-2014, 06:43 PM
Are these still available for the 930?
Rahl
Old 02-18-2014, 08:52 PM
RarlyL8's Avatar
We haven't made any in a while but still have the fixtures.
Old 02-19-2014, 05:11 AM
Brian,
How much power difference did you see with the SSI system versus your header design with equal length secondaries and improved wastegate plumbing?
Did you ever dyno each set up?
Thanks,
Fred
Old 02-19-2014, 09:12 AM
RarlyL8's Avatar
No back to back dynos. We had one client we built an SSI system for who later bought a set of my headers. He really liked the SSIs until he bolted on mine.
Old 02-19-2014, 09:20 AM
I really like the stock like apearance. Most aftermarket headers look cool but are obviously not stock, like when you see blue AN fittings on a classic car.
07 Exige S
Old 02-19-2014, 09:40 AM
16Volt's Avatar
I must be getting old, my first thought was "wow, those look like they would provide better heat".
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 02-19-2014, 09:47 AM
TT Gasman's Avatar
Cost?
Doug
Houston, Texas
997 TT 550RUF
'86 930
Old 02-19-2014, 10:04 AM
beancounter
jwasbury's Avatar
The SSIs provide stupendous heat. I recognized when I bought them that there were choices which gave bigger #s on the dyno. For me, I wanted real heat, plus I wanted something that would have the quality and longevity of the OE parts. That 2nd requirement eliminated 99% of the aftermarket offerings available at the time. SSI was the only choice, and I don't think its possible to do better than them from a quality/longevity perspective.
I have no regrets and no plans to upgrade.
Jacob
Old 02-20-2014, 10:09 AM
Originally Posted by TT Gasman View Post
Cost?
Second this question.
Brain, what would the cost be for a set of the crossover pipes to complete the set up if one already had a set of SSI on hand?
Fredmeister
Old 02-20-2014, 11:21 AM
RarlyL8's Avatar
I'll have to research that Fred as 321 has gone up sense we last made these. Shoot me an email if you don't mind and I'll return it with a quote.
Yes SSI have OEM quality heat. The original 321 exchangers will last a lifetime in most applications.
Old 02-20-2014, 12:28 PM
would these SSIs have any performance advantage over standard (non thermal reactor) headers. They look pretty similar to the normal euro headers, except for material of course
07 Exige S
Old 02-20-2014, 12:47 PM
RarlyL8's Avatar
Yes. The primaries are near equal length long tubes which help with off boost torque and peak HP. The secondary system is a compromise.
Old 02-20-2014, 02:10 PM
Brian I sent a PM for quote.
regards,
Fred
Old 02-26-2014, 12:51 PM
