TurboKraft's Avatar
Very clean.
TR30R? Pretty exotic, usually reserved for endurance racers (ex: Audi R8) and pro rally.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 02-28-2014, 09:24 AM
yes, exotic, but very effective, very very little LAG,
930 1976 , 3L Short stroke 66x98mm , JE pistons 7,6:1 , Rods forged Wossner, SC camschaft , CIS 3,3,L , MSD 6-AL2 programmable , headers RARLYL8 , GARRET TR30R, intercooler 965, TIAL WG 0,9b
Old 02-28-2014, 09:33 AM
I think a2w is ideal packaging for a rear or mid engine high hp turbocharged car. Horizontal and top mounted ics just can't have the same mass flow rate as a front mounted heat exchanger. That said I wouldent really want to cut up my original 930 to install one.
07 Exige S
Old 02-28-2014, 07:36 PM
Originally Posted by TurboKraft View Post
Nice MODE setup in the dp935.
Agreed, but where to place a sufficiently large radiator with good airflow on a stock-bodied 930? Put it in the wing like the stock A/C condenser, or mounted over the engine in place of the stock intercooler?
Thanks! MODE does make some pretty amazing stuff.
Pat Wiliams is the guy who deserves the credit on the engineering.
Because of the extended DP tail we had no problem mounting two Setrab radiators. Perfect for air flow to cool the water. I did do it just for something unique, but we were amazed how the Outlet temps barely budge on repeated high boost runs.
Old 02-28-2014, 08:19 PM
A friend of mine is building a "934" spec EFI engine with watercooled IC-plenums. Hopefully it will be cool enough for ~750hp
Old 03-04-2014, 02:29 PM
spence88mph's Avatar
Love seeing that car above when it pops up time to time. Engine looks awesome, the air only travels a short path through the A/W intercoolers.
'89 911 M491+Turbo
'89 944 Turbo
'88 928S4
'18 C63S Coupe
Old 03-04-2014, 02:34 PM
Is very busy
TheRedSlantnose's Avatar
I'd prefer the air to air intercooler because I think an air to water one would add a little more weight to the car. You can fit an air to air intercooler under a ducktail by using the OEM intercooler, removing the seal around it, and trimming the edges a bit, or by mounting the intercooler at a transverse (side to side) angle. I've seen both methods done before, so it's definitely possible.
Jason
1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser
1986 944 Turbo (951), 350+hp, Guards Red- Track car
2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver
Old 03-04-2014, 02:38 PM
Wonder if one of these would shoehorn under the rear deck lid? Might have to be modded a bit.
63 356 So Called Outlaw
76 930
Old 03-12-2014, 01:07 PM
LMAO! Now that's some serious anti-heat-sink equipment. Hmmm now if I can just reverse engineer it...
Old 03-12-2014, 07:59 PM
Turbonut
Raceboy's Avatar
Originally Posted by Speedy Squirrel View Post
The RUF CTR solution is great for a twin turbo layout, but it is hard to make that layout work for a single turbo. Plus, it requires those inlets in the upper rear fenders, which I think ruin one of the best parts of the vehicle, aesthetically.
Only CTR prototype had NACA ducts in upper fenders and these were discarded in later cars which had just vents in lower rear areas of rear fenders a la 959.
It was done just because air always finds it's way to intercooler, but more important is to create a low pressure area behind the intercooler and that creates air movement.
'83 924 2.5 16v Turbo, 530hp @ 1.5bar
'67 911 widebody hot-rod /2.4S
http://www.facebook.com/vemsporsche
Old 03-13-2014, 02:51 AM
Eddie Bello got his working.
And a dyno comparison vs. his air to air.
1987 GP White 930
1977 Ford Bronco
Old 03-28-2014, 07:16 PM
