Is very busy
TheRedSlantnose's Avatar
Originally Posted by Hams930T View Post
We should link up sometime so I can test yours out. I can tell you if you have the 594 pressure plate or not.
You're welcome to try mine and note the difference. I personally am using this setup from Patrick Motorsports: 930 Lightweight Flywheel & Clutch Conversion Package
Except that I am running their billet 60-2 flywheel for EFI.
You're welcome to test it out and see the difference.
My clutch return spring is intact but the pin that it connects to at the pedal broke - so I have no return spring. I need to fix it...
Chris.
Maybe I can do that sometime, I'll let you know if I'm interested in doing so
Jason
1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser
1986 944 Turbo (951), 350+hp, Guards Red- Track car
2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver
Old 03-03-2014, 09:03 AM
TurboKraft's Avatar
Like Fairman said -- check the omega helper spring under the transmission.
Also make sure the cable isn't worn or binding, adding resistance.
We've installed the -594 "Ruf" and the 935 pressure plate in many 930s, and the pedal effort is hardly stiffer than stock, maybe 10%. That's part of the reason we like them so much.
Tom's UBER930 used the 935 pressure plate, he felt it perfectly civilized and easy to use in stop-and-go traffic.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 03-03-2014, 09:16 AM
Is very busy
I guess I can check that if you say a 935 pressure plate isn't supposed to be that stiff, thanks
Jason
Old 03-03-2014, 09:19 AM
930T Owner
Hams930T's Avatar
Jason,
I can actuate the clutch with my arm pretty easily, if that helps you.
Chris.
Hams930T
2017 Turbo S
Old 03-03-2014, 09:25 AM
Large Member
krasuskyp's Avatar
Jason,
yeah, but... (pic of Chris' arm):
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 03-03-2014, 09:33 AM
Had the brutal stiff clutch like you described. Mine is a Kep stage one. Rebuilt the pedal cluster and did all the adjustments and spring checks and seen some improvement. Then installed a new cable and like magic it is near stock pedal effort. The inner cable wears through the nylon jacket and then binds against the outer cable. When unhooked it slides like new but under pressure it won't
Old 03-03-2014, 09:35 AM
930T Owner
Hams930T's Avatar
LOL!!!!! Dayum!!! You caught me! okay I will admit it; I'm a meathead!
Hams930T
2017 Turbo S
Old 03-03-2014, 09:37 AM
Is very busy
Good one
Jason
Old 03-03-2014, 09:43 AM
Is very busy
Does it require much work to do?
Jason
Old 03-03-2014, 09:44 AM
Is very busy
Jason,
Chris.
There's another guy I know who has a 600 hp 997 Turbo and he can actuate the clutch with just his finger. Just for comparison with a more powerful car than mine.
Jason
Old 03-03-2014, 09:46 AM
930T Owner
Hams930T's Avatar
Well if you're running a cable actuated clutch it will always be stiffer than that.
Hams930T
2017 Turbo S
Old 03-03-2014, 09:56 AM
PrimeMvr's Avatar
+1 I just replaced my clutch cable and for the first time since owning it I can depress the pedal all the way with my hand. My arms resemble a finger on the guy that Pauly posted.
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 03-03-2014, 10:05 AM
Is very busy
I know, I just want to have the clutch be looser so it'll be easier to drive, and so my wife would be able to drive it as well since she has wanted to drive the Slant since I bought it.
Jason
Old 03-03-2014, 10:08 AM
Is very busy
Would it take much work to replace the clutch cable? It'd probably be easier if I did it myself, but if it takes a lot of work, I might have a shop do it for me instead.
Jason
Old 03-03-2014, 10:10 AM
930T Owner
Hams930T's Avatar
Here's a pelican link to replacing the cable/helper "omega" spring that Chris at TK was referring to: Pelican Technical Article: Replacing and Adjusting the 911 Clutch - Page 1
I would look at the cable, boot, clutch return spring on your pedal box, and the omega spring. All those parts should run you around $350. The labor is up to you.
It's not real hard honestly.
Chris.
Hams930T
2017 Turbo S
Old 03-03-2014, 10:16 AM
Large Member
krasuskyp's Avatar
Yeah, but...:
past:
Old 03-03-2014, 10:20 AM
PrimeMvr's Avatar
I had the engine out so there was plenty of room for access, but I don't think it would be too bad with it in. The trickiest part was at the pedal end. I think I disconnected the accelerator linkage at the pedal to gain more access to the clutch pin because the accelerator is easy to detach/attach.
I had no issues pulling the old cable out or putting the new one back through the tunnel. I smeared the outside with a very light coating of lithium grease.
In the back at the firewall, just make sure the cable is pushed in firmly before adjusting the clutch. I cycled it a few times and then double-checked. It hadn't moved.
Old 03-03-2014, 10:32 AM
TT Gasman's Avatar
If this just suddenly happened I would highly suspect the return spring is gone .
Old 03-03-2014, 10:55 AM
Is very busy
Oh, okay, maybe I'll try doing that this weekend, or until I buy a new clutch cable.
Jason
Old 03-03-2014, 11:03 AM
Is very busy
It didn't suddenly happen, it was like that when I bought it.
Jason
Old 03-03-2014, 11:04 AM
