Is very busy
TheRedSlantnose's Avatar
Porsche Crest Stiff clutch
The clutch pedal on my 930 Slant is really stiff, and it makes driving through traffic really difficult as well. I may have it to get to a shop sometime to adjust it. My car does have a 935 pressure plate, but is it actually normal for a 935's clutch to be this stiff?
Thanks,
Jason
1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser
1986 944 Turbo (951), 350+hp, Guards Red- Track car
2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver
Old 03-02-2014, 06:12 PM
DSPTurtle's Avatar
It's not a Honda. Has the stiffness changed recently?
Old 03-02-2014, 06:46 PM
Is very busy
No, the clutch pedal's been stiff since I bought it. It didn't get any looser or stiffer.
Jason
Old 03-02-2014, 06:56 PM
930T Owner
Hams930T's Avatar
Based on your power level stated, it is likely the car has a Sachs 594 pressure plate which would make for a very stiff clutch pedal.
Chris.
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 03-02-2014, 08:21 PM
Is very busy
Chris.
Is there any way to adjust it or should I leave it like that?
Jason
Old 03-02-2014, 08:31 PM
930T Owner
Hams930T's Avatar
You can only adjust the engagement. You would have to change the whole pressure plate and clutch to get a softer pedal. But in any case its just a guess. The Sachs 594 plate is made to hold around 580tq and what you'd find in a "935" package.
Chris
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 03-02-2014, 08:35 PM
Is very busy
Chris
Then I guess I'll leave the way it is in that case, thanks!
Jason
Old 03-02-2014, 08:40 PM
DSPTurtle's Avatar
How much power are you making? 935 might be overkill. Regardless, it's a cable clutch so it's much stiffer and more effort than the sexy new hydraulic clutches.
Old 03-02-2014, 09:08 PM
Is very busy
My car makes 545 hp at 1.25 bar (about 18 psi) of boost
Jason
Old 03-03-2014, 06:21 AM
Large Member
krasuskyp's Avatar
odd your car would retain the OE exhaust w/ that kind of throughput?
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 03-03-2014, 06:28 AM
Is very busy
Well actually, I've always thought my exhaust was custom-built, but if it is the stock exhaust, how could you tell?
Jason
Old 03-03-2014, 06:38 AM
Large Member
krasuskyp's Avatar
sorry - I was just going by the appearance of the tail pipe that I thought I'd recalled seeing in one of your pics you'd posted. I could be wrong...
past:
Old 03-03-2014, 06:41 AM
Is very busy
Oh. Well, my exhaust has only one pipe and not two like the factory exhaust does. The headers are also different as they're not equipped with the factory mufflers as my car has only one main muffler.
Jason
Old 03-03-2014, 06:54 AM
beancounter
jwasbury's Avatar
FYI
If the throwout bearing guide tube is not properly greased, it can make for an extremely stiff clutch. Like other things in life, proper lubrication is necessary for smooth action.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 03-03-2014, 07:10 AM
Large Member
krasuskyp's Avatar
d'oh my bad Jason, got your car confuzed w/ another pic I'd seen - could have sworn I saw OE double tip on one of your pics - sorry 'bout that
clutch stiffness is also very subjective... does your left leg start to start pulsating when you hold it in @ a light?
Hook up w/ Chris since he's local to you and try his... tho... forget what clutch he runs. But compare it to an OEM one and another aftermarket one if you can and go from there...
past:
Old 03-03-2014, 07:15 AM
TT Gasman's Avatar
Check the clutch pedal return spring .
Old 03-03-2014, 07:19 AM
Is very busy
Originally Posted by jwasbury View Post
FYI
I don't really mind the stiff clutch, but in public it would often wrongly accuse me of being a "beginner" as I still haven't gotten used to applying the correct amount of throttle, and having had years of experience driving cars with manual transmissions, it seems a little embarrassing. I usually don't stall the engine doing so, but I do cause it jerk about since my car does not like to be driven slowly.
Jason
Old 03-03-2014, 07:20 AM
There is a clutch pedal return spring in the pedal cluster under the floorboard. They are known for sometimes rusting and breaking in some cars. If it's broken the clutch pedal will be harder to press down.
The 930 spring in no longer available but an SC spring will work.
Some people weld the original 930 one back together if it broke and there's enough left to weld.
I doubt you'll really know what clutch is in your car unless you remove it. A 935 clutch would be expensive and there are better alternatives available.
Old 03-03-2014, 07:41 AM
Is very busy
That's okay.
Well, it's not exactly painful to disengage the clutch, but in fact, the clutch is so stiff it'll give you a cramp if your legs aren't "in shape".
Jason
Old 03-03-2014, 07:51 AM
930T Owner
Hams930T's Avatar
We should link up sometime so I can test yours out. I can tell you if you have the 594 pressure plate or not.
You're welcome to try mine and note the difference. I personally am using this setup from Patrick Motorsports: 930 Lightweight Flywheel & Clutch Conversion Package
Except that I am running their billet 60-2 flywheel for EFI.
You're welcome to test it out and see the difference.
My clutch return spring is intact but the pin that it connects to at the pedal broke - so I have no return spring. I need to fix it...
Chris.
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 03-03-2014, 08:38 AM
