LinkBack | Thread Tools | Rate Thread |
I'm an idiot
1979 "Final Fifty" 930
My advice would be don't even consider a repair. If the repaired part should fail in a way that a piece ended up inside your intake.....goodbye motor. Be conservative-get a replacement part and sleep well.You will feel better and so will your build.
Banned
That would be an easy repair for a good TIG welder.
I know and I have a great guy down the street. I'm truly on the fence. This build is at the 3 1/2 month limit and is making me nuts and the intercooler should be here next week. This sux
Banned
Once repaired, no amount of boost you throw at is will do anything to it. I would have it fixed, without hesitation, if it were mine (depending on what the welder says, of course).
I've gone native
I'd also fix it without a second thought.
'07 997.1tt Blk/blk 600hp, bad to the bone |
Find an AWS certified welder and you'll be back in business.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
I had the same thing happen, same location and had it repaired. No problem.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
Chain fence eating turbo
7.0:1 > 11.3:1
Easily repaired. I've modified these 3.2 intakes and they weld fine, strength won't be an issue.
Not a difficult repair. Bite the bullet and get it done. You won't be sorry.
Rahl |
beancounter
Weld...or JB Weld
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Large Member
aw Frank, shoot - I was all set to click on this post of yours and bust on you for plagiarizing my God Given Rights to that subject line...
...and then I saw the carnage, and making fun of you just didn't feel right. Sorry to see that brutha. I'd totally weld that and run it no worries, but I'm no sexpert... tho... I did stay @ a Holiday Inn Sexpress somewhere at somepoint... Really lookin forward to you virgin pop'age (you must be walkin around sportin permawood)... you'll get there soon enough... hang in there.
Paul... CT | '87 930 | '08 M3 6gang vert | past: | '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq | | '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 | |
Hey Frank, cast aluminum welding could be challenging, but doable with the right TIG welder and proper pre-heat treatment... After done, don't overtorque that particular lobe.
Turbo Hooligan
I would take this as a sign that your supposed to have ITB's…
www.d-zug.com blog.d-zug.com All these guys do is drive too fast, work on cars, chase ******* and drink.. really no fun at all... |
It's interesting that it's the same as mine. I had attributed the failure of mine to metal fatigue from using the stud boss on that runner to support the rear of a full bay intercooler.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold Last edited by sjf911; 03-07-2014 at 10:39 PM.. |
Took it down to a buddy's race shop. Turned out awesome. Thanks guys
^^^wow! That came out great...barely noticeable from the top..excellent!
Rey....77 930 "the Mistress" |
That looks prrrrrreeeettttygood!
Banned
That's some excellent work right there - very nice repair!
Thread Tools | |
Rate This Thread | |
