Mystery toggle switch
There's a small toggle switch just outside of the footwell on my 930 Slant. I don't know what it's for or what it's connected to, and it's always been in the "up" postion. Today it was midway between up and down, and I guess that's when I started having the boost problem. Is this toggle switch connected to my boost controller or something else?
Here's a photo. Sorry it's dark, I couldn't get enough light in the photo, and I put it back to the "up" position: http://forums.pelicanparts.com/uploa...1394405309.jpg Thanks, |
That's the switch to the p*ssy magnet. They made them extra strong in '87. The parts are NLA. Use judiciously.
hahahahahahahahhaah
That's funny, but I really want to know what that switch is for :p
Well it isn't factory so you will need to pull the cover loose and trace the wires.
You got aftermarket Amp or Alarm? It's definitely not stock...
seriously its probably soime aftermarket alarm system or something.
My slant has a switch like that too. I've been afraid to touch it for the last 8 years. Lemme know what you find out!!!
That's the take off switch, it only engages at 350MPH so don't worry...
Now seriously, if you follow those purple w/green connector wires might take you there because those wires are not OEM either. |
Flip it the rest of the way and see what happens next. Maybe it's a on off for a ebc.
ejection seat
which is enTIRELY different than ejaculation seat or erection seat |
High beam switch. Old school Chevrolet style. :)
I'm going to guess on a valet switch or something tied to your alarm. As ohers have stated, the only way you will ever know is to pull the kick panel out and take a look at where the wires go. That isn't an oem switch so not much help on it's purpose. Investigative work will be required here.
Chris. |
I have one & have believed it to be the power antenna. It has a fuse missing under that panel & have never messed with it. Just a thought.
| All times are GMT -8. The time now is 03:09 PM. |
