H4 Conversions
For those that have swapped out their H5s for H4s from our host, what else other than the kit, bulbs and plug adapters are needed? Is it really as straight forward as it sounds?
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 03-10-2014, 10:09 AM
Large Member
krasuskyp's Avatar
depends on what's in the kit?
the harness requires an adapter pigtail to join the OE H5 harness to the H4 receptacle
the trim rings require outer trim rings if you don't want to run chrome or don't want to paint them (advisable anyway, keep moisture out of the adjuster holes). The outer rings need special mounting bolts - a hollow main bolt to secure the inner ring with another bolt that threads into it to secure the outer ring
relaying is advised - JWest kit from host was something like $38
otherwise yes it's as simple as it sounds
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 03-10-2014, 10:30 AM
DSPTurtle's Avatar
Relay for sure
Old 03-10-2014, 11:03 AM
