LinkBack | Thread Tools | Rate Thread |
Large Member
Paul... CT | '87 930 | '08 M3 6gang vert | past: | '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq | | '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 | |
Banned
Weather has been so $hitty that I haven't been able to drive since receiving the advice, but hopefully it works. Guy at NHS was very friendly and helpful.
Richard 1982 930, K27-7200, Ruf wheels, Leask WUR, Tial WG, WEGO IV AFR, RarlyL8 headers & single out muffler, TK I/C 2011 R350 winter beater 2004 BMW R1100S |
Another rattle source I managed to trace to the drivers window mechanism - turned out to be a little wheel that runs in a track that raises and lowers the window. Sorry this is the best beer infused technical description I can come up with right now, but it's pretty obvious when the door panel is off and it's in front of you. Only rattled when the window was up.
Had this rattle 12 years ago - took the door panel off, lubed it up and that fixed it for a while. Needs to be done again though. If it ever warms up here I can get started on all the car projects that can't happen when it's minus friggin 20.
just an update. I am headed back east for a few weeks and will have an opportunity to look into the rattle I sought help with. I will try the suggestions from you all...I will report back. I do once again appreciate the help from the 930 brotherhood!!! wish me luck.
Registered Abuser
the alpine radio i had until recently rattled like a mofo. don't know how i stood for it for so long. i recently replaced it with a new blaupunkt and no more rattles. my NHS boost gauge buzzes too. i will try the spin fix.
River Rat
I keep the windows down and installed a zork ... No rattles here.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs. |
Large Member
I found my headunit rattle/buzz in my M5... it's the tapedeck door. Annoying. FWLIW... my VDO 935 telltale buzzed / rattled too - installing NHS vac/1.5bar and hoping fer silence! Pete, def let us know yer findings, jah? Good luck...
will do brother paul!!
Banned
A couple of solutions for you Nancy-boys that trouble over cockpit rattles:
1) try making gear changes ABOVE 2000 RPM once in a while, 2) switch out your WAM cd for Slipknot 9.0 Live and turn the volume up beyond your pre-set 2 on the dial! And if none of the above works, try growing a pair!!! ![]() |
As a 930 newbee, I have been amazed that the car has no rattles or sqweeks. 37 years old and 108K miles and still strong.
Jeff Fort, Findlay, Ohio 70 914-6 2.7 07 Carrera C2S 05 Cayenne V6 |
Banned
I got rid of an annoying driver door rattle when I first got my car. When you take the door panel off you'll see a long steel linkage rod going from the interior door lock button bellcrank over to the door latch mechanism.
There are little plastic bushings where that rod bends and goes through and hooks up to other mechanical parts and they wear and go away after a while and the rod becomes looser and can rattle. Mine was rattleing against the door frame behind the door panel. I put a piece skinny clear PVC hose over the rod where it was rattleing against the door frame and now it's quiet. Rubber vacuum line would work too. You have to take the door card panel off and find all the linkage rods including the interior door pull lever in the door handle that loosen up and can rattle. Spraying the long rubber door gasket the door seals against when you close it from end to end with silicone spray gets rid of annoying squeaks from the doors and is good for the rubber gasket. That goes for all cars.. especially old BMW's. May not be your rattle but worth a try anyway. The NHS gauge rattle fix is nice to know, I never would haver thought of twisting the gauge and hose to dampen it. Mine occasionally does it too. Sounds kinda like a small tambourine being shaken while accelerating slowly at lower rpms around town. Maybe stuffing some cotton into the hose with a small screwdriver would work too. |
Have the same problem with my boost gauge , I just don't hear it any more. As for a rattle I had one I couldn't find. Drove me nuts finally narrowed it down to pass door. Removed panel and found an extra alarm key .. My local wrench said he searched for one on a customer car in the late 80s and found a beer can in the driver door cavity. Wish I could have a beer at lunch as I heard they had beer vending machines at the factory
found the rattle...it is in the stereo. what to do? it is the original head unit and speakers. I love the originality but the rattle is killing pete
Pete,
no affiliation to this company...try Classic Car Stereo .com They have 911 listed in their search, good luck ! Marty
Porsche builds the 21st century 9146 so easy...even a Cayman can do it ! |
Thread Tools | |
Rate This Thread | |
