Madsimilius
Madsimilius's Avatar
I this a normal k29 ?
Is there any difference in the k29 compressors? I've seen several different designs on it but non exactly like mine? It's a K27/29 turbo and i just took it out to give it a rebuild.
911sc, 3.1, ported 40mm, cams and titanium retainers, carrera 3,2 intake, ms3x, k27/k29, full exhaust,
Old 03-13-2014, 06:18 AM
Madsimilius
I'm also wondering if there is a better compressor wheel for it? Maybe i can mod it when i already have it out?
Old 03-13-2014, 06:26 AM
TurboKraft's Avatar
No, that is not a normal K29. This is what they usually look like:
(Ignore the missing compressor nut, this turbocharger decided to eject it on the dyno...)
Here is a close up of what the compressor usually looks like:
I've never seen one like yours. Is the usual K29 compressor better? Maybe, it depends on your wheel's specifications and how much boost you are running.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 03-13-2014, 11:33 AM
Rocket Scientist
Why don't you post the info on the data plate?
Old 03-13-2014, 01:03 PM
TurboKraft's Avatar
Because neither of those is a regular K29.
Top photo = Ruf "Grosse K27" from a 3.4L BTR, unique turbine wheel, unique number. Total oddball, parts are long since NLA.
Lower photo = K27 with comp cover modified to accept a regular K29 comp wheel, so the numbers on the tag are irrelevant.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 03-13-2014, 02:14 PM
I so respect the expertise on this forum!
Old 03-15-2014, 06:45 AM
Crotchety Old Bastard
RarlyL8's Avatar
Every tuner shop has their version of a hybrid turbo. The info plates are typically left intact from the donor turbo leaving a mystery for the rebuilder or any susequent owner. We typically scrap everything but the correctly numbered housings and rebuild to spec with new KKK/BW parts.
Old 03-15-2014, 07:55 AM
Madsimilius
Ok, i thought it would be fun to find out. I searched the number on the turbo housing and all i could find was that it was mentioned with volvo marine and diesel :P I'm guessing it might be from a diesel boat engine then.
Im running 1.2 bar and have full boost at about 3800 rpm on a 3.1 sc engine with 3.3 mahle c&ps
Old 03-16-2014, 05:48 PM
