Pezho405's Avatar
Clutch spring...
Hey i just got my clutch spring, and was told i would have to take out the pedal box to be able to put it in?? i tried getting on just by depressing the clutch all the way but got alittle frustrated and decided to do it this weekend instead.
Is there a way to just stretch it on? secret tips?
1984 930 3.3 Turbo
2004 BMW X5 4.4i
1983 BMW 320i
1993 Vaz 21063
Old 03-13-2014, 02:50 PM
I've gone native
Tt surgeon's Avatar
Yes, I did it, you need a auto parts store brake tool to stretch the spring. If you do a search here it should pop up.
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 03-13-2014, 05:33 PM
930T Owner
Hams930T's Avatar
Yep many different methods to make this happen. I personally did the trick of expanding the coils by inserting washers in between. I found this trick to be fast and easy - like 10 minutes.
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 03-13-2014, 06:15 PM
Pezho405's Avatar
Great thanks!
I was actually trying this with some coins with the old spring, will try it with new spring tomorrow. now that i know someone else has had succes with it
1984 930 3.3 Turbo
2004 BMW X5 4.4i
1983 BMW 320i
1993 Vaz 21063
Old 03-13-2014, 08:36 PM
I've gone native
Tt surgeon's Avatar
Yes, almost forgot that, I also stacked quarters btwn the coils.
C
'07 997.1tt
Old 03-13-2014, 09:40 PM
930T Owner
Hams930T's Avatar
It's really easy honestly with the quarters trick. In fact, it took me longer to recover the quarters that decided to nestle themselves under the pedal box...
Also in doing this method, I found it easier to hook the spring to the pedal post first and then pop it on to the post at the rear that is attached to the pedal box. You may give that a try if you have any issues.
Chris.
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 03-14-2014, 09:25 AM
Pezho405's Avatar
Chris.
OK ill try this as well. Just punctured my finger with a screw comming from the floor... washing it out ATM
1984 930 3.3 Turbo
2004 BMW X5 4.4i
1983 BMW 320i
1993 Vaz 21063
Old 03-14-2014, 10:21 AM
Pezho405's Avatar
Done.
1984 930 3.3 Turbo
2004 BMW X5 4.4i
1983 BMW 320i
1993 Vaz 21063
Old 03-14-2014, 11:13 AM
Pezho405's Avatar
Used 17 coins double stacked.
1984 930 3.3 Turbo
2004 BMW X5 4.4i
1983 BMW 320i
1993 Vaz 21063
Old 03-14-2014, 11:14 AM
DSPTurtle's Avatar
$4.25 huh? I bet you can't buy a tool that cheap.
Old 03-14-2014, 06:03 PM
Pezho405's Avatar
I actually used Nickles mostly.
1984 930 3.3 Turbo
2004 BMW X5 4.4i
1983 BMW 320i
1993 Vaz 21063
Old 03-15-2014, 03:04 PM
