oilonly's Avatar
WUR fuel line fittings size question
What are the proper size/descriptions of the fittings on these lines from the WUR to the Fuel head? I'm rying to give BoxsterGT the proper sizes for a fabrication in an email.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 03-18-2014, 03:24 PM
BoxsterGT's Avatar
Porsche Crest
If the turbo version uses the same size Banjo as a 911SC, then the fitting size is 8mm and I do have these fittings in stock.
I am happy to help w this.
Len
Old 03-31-2014, 07:02 AM
oilonly's Avatar
Thanks for the reply Len, i was hoping on getting a concrete answer this way we can have them made up longer so i can custom mount my WUR. Haven't had the time to take my old ones off to send you either. 100 percent want to do it as i have figured where i want my Wur to be located.
Old 03-31-2014, 07:39 AM
i can check tonight.
Im planning to replace it next week anyway, I see a small nick that bothers me (as it should)
I dont think this ones even listed in the PET Katalog
Old 03-31-2014, 09:42 AM
Hose
The original fuel hose you look at the picture you can buy it anywhere?
Old 03-31-2014, 12:00 PM
oilonly's Avatar
jeos here are the part numbers for both of those lines, you can buy them at Pelican.
OEM 93011030205
OEM 93011030503
Old 03-31-2014, 03:28 PM
Metal Guru
911nut's Avatar
Anther option is to buy the correct size line and Odteiker clamps from Bat Inc and re-use the fittings. I plan to do just that so I can adjust my WUR without straining the crap out of the too-short line.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 03-31-2014, 03:47 PM
oilonly's Avatar
Yeah that is what i have to do, take off the old lines, but i will send them to BoxsterGT to make them up. Just thought i could get correct size fitting info so i can drive the car and not have to take off the lines for the fittings for him.
Old 03-31-2014, 03:58 PM
12 at the fuel head, is this what you want?
Old 03-31-2014, 04:57 PM
oilonly's Avatar
That's a different line but thanks. I'm just going to take off my old lines and send them to Len. Best way to make sure we get it right.
Old 03-31-2014, 05:53 PM
Metal Guru
911nut's Avatar
FYI, here's what BAT Inc made up for my wur return line. Cost was $21, line material is TFE and it's good to 1000 psi burst strength.
Paul B.
'91 964 Turbo
Old 04-26-2014, 05:55 AM
oilonly's Avatar
Nice 911nut and thanks for your info. I ended up buying the two WUR lines here used and have sent them to BoxsterGT so no issues on what to make. How did your WUR feed line work out?
Old 04-26-2014, 02:54 PM
BoxsterGT's Avatar
Porsche Crest
Here are the typical Factory CIS Polyamid fittings as used on the early 911SC & on some flex lines of the 930..............
They are M12 Banjos at the FD with a M12 Female at the Injector. The Banjo Bolt is M8x1.00 thread pitch. Barbs on the tube end are one-way. Once inserted they will not rotate or come apart. If they rotate they have failed. Only way to separate them is with heat, as in melting the plastic. No other way is possible for risk of damage to the actual barb.
The original lines having a rubber sheath are not hose but Polyamid tube with a rubber coating that is no longer available in this size.
The aftermarket lines above in post #11 show a crimp sleeve and a crimp next to the fitting. It may have a unique type of banjo designed for this method of securing the tube. However, trying to clamp the Polyamid tube is not effective, and the barbs are not designed for soft rubber hose & any kind of clamp, even the good Oetiker ones.
Hope this helps.
Len
Old 04-27-2014, 02:28 PM
Metal Guru
911nut's Avatar
I haven't replaced it yet but when I do I will most likely buy a stock one.
Paul B.
'91 964 Turbo
Old 04-28-2014, 07:40 PM
oilonly's Avatar
Had some time today so i relocated the WUR with new lines supplied by BoxsterGT.
Old 05-04-2014, 02:33 PM
I've gone native
Tt surgeon's Avatar
Al, that is really nicely done!
C
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 05-04-2014, 04:47 PM
BoxsterGT's Avatar
Porsche Crest
oilonly-
I am happy to see you received the new longer lines and have them installed.
Please do not think I am being critical. I thought the WUR needed the heat from the engine to maintain correct fuel mix? Perhaps the heating element itself is enough to do this.
Do you have a wide-band O2 sensor that records fuel mix? So you can monitor this.
Just thinking out loud.
Len
Old 05-04-2014, 04:50 PM
oilonly's Avatar
Originally Posted by BoxsterGT View Post
oilonly-
Len
Yes i have wide-band 02 sensor Len. No change in WUR operation with it installed in it's new location so far. The bracket i have it mounted on is only a first mock up and will be improved. The lines were perfect length. Now next project is to learn how to tune a WUR in this new easily accessible spot.
Thanks Chris.
Old 05-04-2014, 06:27 PM
Metal Guru
911nut's Avatar
If Oilonly lives in a cold climate and uses his car in low temperatures it will be an issue as he won't get the wur warm enough to get to warm cp. On the other side, the wur won't get heat soaked as much before a warm start so the idle will be better in that condition.
Paul B.
'91 964 Turbo
Old 05-05-2014, 09:38 AM
Motor looks clean and WUR mod looks right - nice job.
Are you making your WUR adjustable?
Old 05-05-2014, 02:24 PM
