LinkBack | Thread Tools | Rate Thread |
Need help with clutch cable routing
1988 930 Venetian Blue |
Banned
Hello Jeff - the way you have it in the above pictures is "mostly" correct (above the throttle bell crank), but you need to turn/rotate the cable housing a bit to the left so that it arcs over the rod and just to the left of the downward facing ear (I'm referring to your first pic). And believe it or not, it does lightly touch there, but when the arch is right, the contact is so slight that it is of no consequence to the cable housing or crank.
Here is a picture taken from the Pelican Tech article on clutch cable replacement - not a 930 transmission and the pic is sideways, but I think it will help you visualize what I'm talking about - http://www.pelicanparts.com/techarticles/911_clutch_replace/pic22.JPG Last edited by Ronnie's.930; 03-18-2014 at 09:55 PM.. |
Thanks Ronnie! I will make that adjustment. That pic definitely helps.
Aprreciate the help!
Smart quod bastardus
Can you describe more details about how you fed the cable thru the firewall to the clutch pedal.....this would be good info. By the way you could zip tie the clutch cable to the hose that runs alongside it clamped to the chassis to get it to stop rubbing on the throttle linkage, I did this without any problems so far. It lifts it enuff away to get a slight clearance. Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Thread Tools | |
Rate This Thread | |
