-   -   headlight cleaning nozzle (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/804138-headlight-cleaning-nozzle.html)
jeos 04-01-2014 11:56 AM
Hello,
I have finally found high model headlight cleaning nozzle and to mount them. but the newer valves are used, or should it be the original hook which locks?http://forums.pelicanparts.com/uploa...1396382041.jpg
http://forums.pelicanparts.com/uploa...1396382067.jpg
stevie 77 930 04-01-2014 12:04 PM
The locking tab is suppose to lock onto the nozzle and it looks like one of the locking tabs is broken anyway. Use the new version of check valve to assure proper funtion. They are a pretty tight fit so they are not going anywhere as long as the nozzle is not cracked.
I used all new hose and claps while i was at it.
jeos 04-01-2014 12:09 PM
OK, that will I do, Thanks for the help
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
