AN Hard Lines on 3.2 Intake
I'm starting the phase of fabricating fuel lines for my EFI conversion and I'm going to be using AN fittings and lines for everything.
Is it ok to run an aluminum or stainless hard line from one fuel rail to another with the 3.2 intake? I'm trying to avoid the big loop of fuel hose that is typically routed across the fan.
Is the 3.2 intake split because it needs to allow for expansion or was it made that way to make it easier to cast the part?
1987 GP White 930
1977 Ford Bronco
Old 04-02-2014, 08:43 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
No... You need a flexible line in between to allow for expansion and vibrations. Just run a AN fitting at each end and make a hose to connect the two. I typically run a single feed line to each rail and then crossover at the rear to the regulator and return from the regulator at the other end.
87 911 Carrera platform
Twin Garrett's, Big Valve, Xtreme Cylinder Heads, JB Racing cylinders and machine work, custom JE pistons, GT2 EVO cams, GT3 oil pump, modified 3.2L intake, 80mm TB, custom Intercooler, equal length headers, DFI, KEP Stage 2 custom twin disc, G50 custom gear set, LSD, Tilton trans pump, Fluidyne cooler
Old 04-02-2014, 09:56 AM
E-85 sippin drunk
turbobrat930's Avatar
Sent you a PM...
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 04-02-2014, 11:10 AM
