16Volt's Avatar
B&B Intercooler Seals
Does one just re-use the inlet/outlet o-rings on the stock intercooler when replacing with a B&B short neck unit?
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 04-02-2014, 11:44 AM
mark houghton's Avatar
Yep, I believe the OEM o'rings are the correct size (worked for my BB anyway). Check 'em for condition, of course.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 04-02-2014, 11:54 AM
16Volt's Avatar
And the factory shroud has to come out it looks like. Anything I should know about the process to remove it?
Looks like I will fab a replacement since the used cooler I bought didnt come with a B&B shroud.
Old 04-02-2014, 12:14 PM
It doesn't hurt to have a few extras on hand. They are pretty easy to pinch and cut.
1987 GP White 930
1977 Ford Bronco
Old 04-02-2014, 12:24 PM
TurboKraft's Avatar
The B&B intercooler plate is flat sheet metal, cutout for the IC and the mounting holes. They'll likely sell one to you if you don't want to make on from scratch.
Yes -- original o-rings.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-02-2014, 12:48 PM
16Volt's Avatar
Dug in and got it done, shroud was a pain to get out with a normal allen wrench. Time to go tool shopping.
Old 04-02-2014, 02:06 PM
Yeah, I had to take my shroud out as well. Never did worry about a tight seal since the B&B fit really close to the grill. Purists would say you need to seal to assure maximum air flow through the IC.....but I'm not a purist and didn't see sustained on-boost runs (i.e., tracking) so never worried about it.
Old 04-02-2014, 06:59 PM
Crotchety Old Bastard
RarlyL8's Avatar
You should use new O-rings on your new inercooler. Old O-rings get stretched out and can pinch during installation. The benefits of shrouding your intercooler are worth the effort. No need to have an intercooler if air goes around it rather than through it.
Old 04-03-2014, 04:58 AM
Correct, Brian. One of the finishing touches I had put on the back burner, fabricating a seal.
Old 04-03-2014, 05:40 AM
16Volt's Avatar
The o-rings are only a few hundred miles old since I replaced them so I re-used them.
The B&B does fit flush against the tail so I dont think I am going to run a seal. There is however a 5 or 6 inch gap on the drivers side front corner that would normally be filled by the shroud so the plan is to block that off.
Old 04-03-2014, 01:01 PM
^^^ I believe you attached an unedited file...
Old 04-03-2014, 01:30 PM
16Volt's Avatar
Not showing up for you? I hate what Yahoo has done to Flickr.
Old 04-03-2014, 01:32 PM
cdill's Avatar
I just added the B& B cooler to my car as well. You are right it fits right up against the tail, but with out the shroud it does allow air to pass right by the cooler. I called B&B and they sent me one for $100 its a very easy install and directs air exactly into the cooler.
Old 04-03-2014, 01:33 PM
They work for me but I can't argue with that. I hate the new "features" they have added.
1987 GP White 930
1977 Ford Bronco
Old 04-03-2014, 01:42 PM
The other way around... too much "unrelated" stuff in there, check it out.
Banned
Yep - pics of the local foliage and so forth (didn't look at all of the pics so might be some nudes in there, too)!
Old 04-03-2014, 02:00 PM
16Volt's Avatar
Yeah, everything is a stupid slideshow now. Instead click-through going to the image it goes to the entire photo-stream. Hope you guys enjoy pics of my Moms visit.
The only nudes in there are of Paul so there is nothing we havent all seen before anyway.
Cdill - do you have any pics of what they sent you?
Old 04-03-2014, 02:14 PM
Banned
Ahhhhhhh, so that was Paul looking disturbingly like a Ken doll "down thar"?! I couldn't tell it was him with that leather, zipper-mask covering his head!!!
Old 04-03-2014, 02:23 PM
cdill's Avatar
16volt here is the best photo I have. It is basically a laser cut piece of sheet metal. That being said it is a perfect fit. You may also notice there is a piece of black foam tape on it. This is because it rubbed slightly on my cooler and scratched it (mine is black)
Old 04-03-2014, 02:28 PM
If you choose the HTML radio button instead of embed it will link to the image and remove the slideshow arrows.
photo 2
1987 GP White 930
1977 Ford Bronco
Old 04-03-2014, 04:25 PM
