sjf911's Avatar
Short bell housing conversion
I am planning to swap my 915 for a short bell 930. I realize I need an early clutch setup but what flywheel and starter ring gear is needed or compatable with a 9 bolt crank for this swap? Any recommendations for specific clutch components(shooting for 500chp)?
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 04-05-2014, 09:24 PM
flywheel
Here's a pic of a stock 9 bolt flywheel from my 87/930, hope this helps. Philip 930 parts #2 F/S
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 04-06-2014, 06:25 AM
sjf911's Avatar
Thanks Phillip, I don't know if a later flywheel will work as the starter ring gear is place further back in the short bell housing. All I can find so far is the Patrick Motorsport lightened flywheel (PMP2409LWFW) anyone know if there are other options? Anyone successfully done this conversion and wish to share their experience and equipment choices?
Sapere aude
Old 04-06-2014, 09:24 AM
TurboKraft's Avatar
1976-77 ring gear.
Either flywheel.
Yes, happy to share. Call or PM.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-07-2014, 10:48 AM
930/66's Avatar
I have the Kit from PM for the short Bell housing.
I do not convert to a G50 but i use the lower profile pressure plate and spring hub disc kit
Service and quality are fine.
87 930 3.4, PT5862, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 04-07-2014, 11:07 AM
930/66's Avatar
here is the Flyweel:
Old 04-07-2014, 11:19 AM
sjf911's Avatar
Originally Posted by TurboKraft View Post
1976-77 ring gear.
Either flywheel.
Thanks Chris.
Sapere aude
Old 04-08-2014, 03:34 PM
sjf911's Avatar
Thanks Thomas. I have the 915 Centerforce clutch and really like it. The only downside is it is stronger than the transmission.
Sapere aude
Old 04-08-2014, 03:37 PM
