Mike80911's Avatar
Location: New York Where only a criminal can have a gun
Need Advise Grinding Noise From Rear
I took my car on the first ride of the season today after a long winter nap and of course something went wrong. As I slowed down to about 10 MPH I heard a grinding noise coming from the rear of the car. The noise got progressively worse as I applied the brake. I limped home and thought either the pads were stuck or shot or maybe something came loose in the e brake set up. Took both sides apart removed the rotors and found nothing all is normal and the pads are like new.
The only thing I see underneath is the right side CV boot has a huge hole in it and I would imagine all of the grease is gone. Would this cause a grinding noise? I always thought CV joints clicked when they went bad. Could that be the problem or can anyone else think of what else would cause this?
Thanks for any advise
86 930 Grand Prix White
04 Cayenne
1970 Chevy Nova SS
Old 04-06-2014, 07:14 PM
Non User
infraredcalvin's Avatar
Rear wheel bearings... Not a fun job...
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
'75 914 GT clone project
'71 914 track car
Old 04-06-2014, 07:18 PM
Mike80911's Avatar
That is what I figured thanks
04 Cayenne
1970 Chevy Nova SS
Old 04-06-2014, 07:46 PM
Sounds like bearings, as mentioned above.
I had mine replaced last year, as well as the axles. I would recommend having a professional do this one as getting the bearings out does not look like an easy job.
Old 04-07-2014, 06:23 AM
Well you know you're into it for at least a CV joint. I'd suggest you fix that and see if it cures your noise?
Wheel bearing job is doable but removing the arms and R&R-ing everything related is not a small task. Search here for plenty of threads on that beast of job.
1986 930, 1969 Mach1, 2003 540 Sport, 2016 R1200RS
Old 04-07-2014, 06:27 AM
Mike80911's Avatar
Thanks guys
04 Cayenne
1970 Chevy Nova SS
Old 04-07-2014, 07:38 AM
rear bearings are easy, Takes an afternoon . just a bunch of unbolting and re bolting
Local shops here quoted crazy money
remember the factory service manual says to heat the trailing arm
I bought this tool :
Bearing Tool
I may sell it
stefan
Old 04-07-2014, 08:50 AM
mark houghton's Avatar
One other possibility could be your emergency brake shoes. I've never been into mine so can't speak with any authority, but aren't they a completely separate mechanical system from the hydraulic calipers?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 04-07-2014, 08:56 AM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
I agree with Mark, the rear wheel bearing is a slow progressive failure not an overnight phenomenon.
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 04-07-2014, 09:13 AM
Does the noise stop or change if you're moving and apply the ebrake? Check your ebrake shoes (yes independent from the calipers) and your regular pads as well. Next inject grease into the boot/cv joint and see if the grinding stops or slows, if so there's your likely answer. You can learn a lot by putting the wheel up and giving it a couple turns.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 04-07-2014, 01:20 PM
Non User
He said he took apart to check the ebrake and all was normal, so,aside from cv, next likely culprit is the bearing... Especially if the car was sitting for winter? When one goes bad, one day you happen notice it, then it gets progressively worse... Not sure you could say that it's not an overnight phenom...
'71 914 track car
Old 04-07-2014, 01:21 PM
Ahhh....so he did! I missed the "e".... Thanks.
Old 04-07-2014, 02:34 PM
Mike80911's Avatar
Took both sides off and they were both fine
04 Cayenne
1970 Chevy Nova SS
Old 04-07-2014, 05:16 PM
Mike80911's Avatar
Thanks for all of the help. I have been reading the threads on the bearings and I think with the proper tools it should not be an extremely hard job. I called my local shop and he said he can't get to it for a couple of weeks. I think I might tackle the job myself and replace both sides as well as the fronts. I figure that they are all 30 years old so if I replace all I am good for another 30 years.
04 Cayenne
1970 Chevy Nova SS
Old 04-07-2014, 05:20 PM
Mike80911's Avatar
Bearing Tool
I may sell it
stefan
Sent you a PM
04 Cayenne
1970 Chevy Nova SS
Old 04-07-2014, 05:21 PM
Non User
Take a look at post 21 (top of page), I used this to do mine... Cost me 15-20 bucks, used it on both sides. First one takes a while just to figure it out, then the 2nd goes much faster.
Rear Wheel Bearing Removal
'71 914 track car
Old 04-07-2014, 07:39 PM
Mike80911's Avatar
Update. Pulled the left rear side apart and the inner wheel bearing is shot so ordered both sides as well as the fronts. I figure I will change all while I have the car apart rather than hope that another bearing does not let loose when I am somewhere far away.
Thanks again for all of the help as usual the best advise anywhere.
04 Cayenne
1970 Chevy Nova SS
Old 04-09-2014, 11:12 AM
Mike80911's Avatar
Got the car all apart removed the axle and spindle. Replaced the outer race. Removed the inner bearing and race. Now for the issue I am installing the new inner bearing and I cannot remember which way the race came out. I am not sure if the race goers in with the bearing facing the outside of the car or goes in with the bearing facing the seal and the transmission. Does anyone know for sure which way the inner bearing faces?
04 Cayenne
1970 Chevy Nova SS
Old 04-17-2014, 10:37 AM
