-   -   Power seat - wiring questions (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/805259-power-seat-wiring-questions.html)
16Volt 04-08-2014 09:06 AM
86 930 w/power and heated sport seats
When I got my car the rear up/dwn adjustment was flakey but then stopped completely. I got only a click and buzz when pushing the button. In a burst of over confidence I attempted to remove the switch to clean and re-install. As with most of my project this turned from clean and re-install to remove and break completely. I pulled the fuse and decided to tackle it another day.
I bought a new seat switch and a few days ago set about pulling the seat to replace the one I mangled. I managed to get all the bolts out even though someone had previously nearly stripped the heads. Does pelican sell replacements?
<a href="https://www.flickr.com/photos/looneys_on_the_lawn/13560606583" title="IMG_6144 by Shannon, on Flickr"><img src="https://farm3.staticflickr.com/2876/13560606583_009ac479da_c.jpg" width="800" height="534" alt="IMG_6144"></a>
Time to buy a real set of allen sockets as I had to break out the "cheapass screw driver thingy" again.
Once free there was of course evidence of a prior break-in given the amount of broken glass under the seat.
<a href="https://www.flickr.com/photos/looneys_on_the_lawn/13560589553" title="IMG_6142 by Shannon, on Flickr"><img src="https://farm8.staticflickr.com/7021/13560589553_72fdc3f1e3_c.jpg" width="800" height="534" alt="IMG_6142"></a>
<iframe src="https://www.flickr.com/photos/looneys_on_the_lawn/13560597703/in/photostream/player/" width="800" height="534" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
I assume this is why the car has the stupid car alarm and new stereo hacked in by Car Toys. I also found this plastic fastener, any ideas where its home is:
<a href="https://www.flickr.com/photos/looneys_on_the_lawn/13560562555" title="IMG_6146 by Shannon, on Flickr"><img src="https://farm4.staticflickr.com/3741/13560562555_7153765577_c.jpg" width="800" height="534" alt="IMG_6146"></a>
<a href="https://www.flickr.com/photos/looneys_on_the_lawn/13560617143" title="IMG_6145 by Shannon, on Flickr"><img src="https://farm8.staticflickr.com/7008/13560617143_c6806b0d32_c.jpg" width="800" height="534" alt="IMG_6145"></a>
So the switch appears to pop into its bracket from the outside of the seat, is that correct?
<a href="https://www.flickr.com/photos/looneys_on_the_lawn/13560502905" title="IMG_6139 by Shannon, on Flickr"><img src="https://farm3.staticflickr.com/2845/13560502905_a3abbe1c6f_c.jpg" width="800" height="534" alt="IMG_6139"></a>
Wiring wise it has to female spade connectors which seem to run to the motor itself then it has two male plugs.
Do they just press into this big connector?
<a href="https://www.flickr.com/photos/looneys_on_the_lawn/13560520585" title="IMG_6141 by Shannon, on Flickr"><img src="https://farm8.staticflickr.com/7191/13560520585_c62572a075_c.jpg" width="800" height="534" alt="IMG_6141"></a>
I ran out of daylight and had to re-install everything but I would like to get this all taken care of this weekend while installing the PLX modules (anyone have a good idea for sourcing switched 12v under the seat for these?) so as to be totally done with removing the seats for the foreseeable future.
T77911S 04-08-2014 10:14 AM
are you still using the O2 sensor
16Volt 04-08-2014 10:42 AM
No, the factory o2 sensor (which is currently unplugged) is not being used. I am putting the WB sensor in its bung.
mark houghton 04-08-2014 10:57 AM
Some mixed opinions about using that location for a WB O2 sensor...do a search for more info. Get's pretty hot there, supposedly hard on sensor life. A good/proper heat sink would probably be mandatory in that location. Technically you should be downstream from the turbo as far as you can get.
Sorry for the hijack....
16Volt 04-08-2014 11:31 AM
Yeah, O2 placement options are about nil with the B&B headers (3 inches total to work with before the turbo).
http://www.bbexhaust.com/car/930/ima...0T-headers.jpg
reachme 04-08-2014 12:41 PM
You sure are working in some strange yellow light. Look up, you might see a vortex about to drop down.
Yes that switch does pop in, best to push from behind or you might do some damage.
Picture to show.
http://forums.pelicanparts.com/uploa...1396988763.jpg
As far as power, yes they slide in from behind. This might help.
http://forums.pelicanparts.com/uploa...1396988981.jpg
But rather than buy a new switch, there is a common issue with the current one. The contacts points are very small and just need a little cleaning. It's really an ingenious switch inside (read overly complicated). This is a four way switch but mechanism is the same, the red circle is where contact is made-just clean that up and then reassemble. Test with an ohmmeter before reinstallation and you'll be good for another 30 years or so.
http://forums.pelicanparts.com/uploa...1396989489.jpg
16Volt 04-09-2014 06:52 AM
Perfect, thats what I was looking for.
Unfortunately I already picked up a new switch since the old one puked all the balls and springs out over my garage floor. Oh well.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
