Banned
Paul, no need to lie about the copious beer consumption - we all know that your intent was to use it as an emotional lubricant prior to springing your, ummmmmmm, "intentions" upon Jacob! Did it work?
Old 04-28-2014, 01:41 PM
Large Member
krasuskyp's Avatar
With a Rebel Yell!
Mmmmm... shinybits, on mah desk!
(shipped to the er um uh wifefriendly address)
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 04-29-2014, 07:53 AM
^^^ LOL. Are u installing those coils in addition to the TBs or in liue of them?
Old 04-29-2014, 08:10 AM
Large Member
krasuskyp's Avatar
lieu... tb's gone byebye
500# springs await these @ home
these are Clint's re-valved (silver) sport's... pretty schnazzy!
past:
Old 04-29-2014, 08:17 AM
Banned
Ha - hilarious Billy Idol reference and "wife friendly address" comment in the span of three, short sentence fragments - both inciting a hearty, as they now say "LOL" on my end!!!! Good work, sir!
Old 04-29-2014, 08:48 AM
Brando
quattrorunner's Avatar
Smart man.
Two addresses to confound and confuse. Smart.
Turbo powa!
1977 911s. it's cool
Old 04-29-2014, 08:57 AM
16Volt's Avatar
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 04-29-2014, 10:10 AM
Cool. Are u reinforcing the shock towers or changing the load points?
Old 04-29-2014, 10:28 AM
Banned
Originally Posted by Miguel Antonett View Post
Are u . . . changing the load points?
Miguel, I am quite certain that ole' Paulito is more than satisfied with his, ahem, "load point"!!!
Old 04-29-2014, 10:54 AM
Large Member
krasuskyp's Avatar
for normal street use and an occasional DE, non-reinforced should be fine
Clint said he tracked the beejebus out of his sans and all's swell
past:
Old 04-29-2014, 11:03 AM
proffighter's Avatar
I drove only on street and never track-used, but had cracks all the same...
Roland
930 Turbo '81 Too many modifications to list
Old 04-29-2014, 11:16 AM
Paul, I believe that the stresses on the rear are ways greater than the front due to the squatting/or lack off under acceleration/decel... The rear shock towers reinforcing (spider) is not really a big deal to do and will help to minimize stress cracks. M2c
Old 04-29-2014, 01:50 PM
Banned
Paul, not to harp or be a pain in the ass (you've already gotten the same input here), and no disrespect to Clint, but he simply got lucky. I can assure you that those damper towers are not designed to take spring and wheel assembly loads, and be subject to the moving weight (up or down) of the engine, transmission, and rear portion of the tub. The bottom line is you will likely regret not reinforcing those mount points if you decide not to do so. Break out the cutting wheel, welder and plate steel, bi@ch!!!
Old 04-29-2014, 02:02 PM
MikeD930's Avatar
Borrowing Paul's vocabulary...Noice!!!
So Paul...you gave in to having full coil overs! You're gonna luv it for it's simplicity in setting ride height. Just keep an eye on the shock towers. I'm surprised you're not going to brace it since you got the engine out. I suppose there's too much stuff in the way or lack of time? Also, make sure you have helper springs to keep the main springs taut during full rebound.
MikeD
'87 930
Old 04-29-2014, 03:12 PM
Dude. You are going to town. I thought I had bad case of the while your in there. Good on ya brother.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 04-29-2014, 04:29 PM
Turbo Hooligan
86 -89 turbos got tower reinforcements from the factory. earlier cars weren't so lucky. I see you took my advice!
www.d-zug.com
blog.d-zug.com
All these guys do is drive too fast, work on cars, chase ******* and drink.. really no fun at all...
Old 04-29-2014, 08:57 PM
Large Member
krasuskyp's Avatar
How can one NOT listen to The Oracle According To Pete - The Porsche Whisperer (TMpending)???
and w/ a colossal 2nd from FRANK
pretty excited by it
MikeD!!! Great usage of NOICE... you're coming along quitenicelike heh heh! I'm gonna try running commando on the helper's, and will add them later if the need is evident.
I figure what the heck... weld NOW - or - weld LATER
I'm more hoping Peteski's righto...
past:
Old 04-30-2014, 08:56 AM
Banned
So in your opinion, those small sections of folded steel, welded (on the ends only) to the outboard side of the shock tower and tub, is adequate reinforcement for adding coilovers? It looks like those reinforcements are intended to help keep the tower area from flexing left and right rather than as a reinforcement for a coilover conversion.
Not trying to be a Richard here (or a killjoy for Paul's suspension mod), but am genuinely interested in your opinion (and the "why", of course).
Old 04-30-2014, 09:08 AM
Large Member
krasuskyp's Avatar
listen, Little Ronnie(Richard)...
ha!
changin gearz
what's the source for a silicon reducer coupler for a solution to 'this'? (up-pipe is a K27-type tapered fitment):
I've got a Vertex on the compressor outlet that came w/ the unit that you can see above, which upon Google'age'ing I find:
Silicone Hose: Straight Silicone Reducers/Transitions, 3 & 4 Ply Polyester - Venair
Go w/ one of them Venair's, or any other referrals / suggestions? I ran a Venair on my urS6 @ one time a zillion yrs ago, high quality unit certainly...
past:
Old 05-01-2014, 06:28 AM
Large Member
krasuskyp's Avatar
ha!
changin gearz
what's the source for a silicone reducer coupler for a solution to 'this'? (up-pipe is a 965-type tapered fitment):
past:
Old 05-01-2014, 06:29 AM
