911 / 930 heat exchangers
Does anyone know the difference between heat exchangers for a 911 Carrera part number 93021102901 differ from 930 heat exchangers part number 93021102103. They look very similar and appear as though the 911 set will fit a 930.
Old 04-14-2014, 10:04 AM
If you put the 911 headers on the 930 there is no provision for any of the turbo components. If you have a 930 you must use the 930 headers.
Old 04-14-2014, 10:53 AM
TurboKraft's Avatar
For one thing, The Carrera's heat exchangers' cylinder head flanges have larger ports, and do not have the rings that insert up into the heads' exhaust ports.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-14-2014, 11:06 AM
Thank you very much for the quick and informative response.
Old 04-14-2014, 12:55 PM
Crotchety Old Bastard
RarlyL8's Avatar
The Carrera heat exchangers will fit 930 ports, the 930 heat exchangers will not (properly) fit Carrera ports. Long studs are required for the Carrera exchangers. The Carrera exchangers will bolt to the 930 J-pipe as they do a 911 catalytic converter. The heater system is different and requires the 930 adapters on the front of the engine that feed from both sides of the engine fan shroud.
Old 04-14-2014, 06:08 PM
Thank you Brian.
Old 04-15-2014, 07:05 AM
