Turbofrog
smurfbus's Avatar
I just rigged up boost logging again after I had burnder my previous MAPsensor with 12V.
Here is a pic of 930 short ratio trans on 1st to 2nd and another pic of 4th gear WOT. Turbo is Holset 40super with the biggest turbine housing for T3 flange 18cm. 964 cams, 38mm intake ports, CIS SP 6bar, wcp at 6.3 bar idle and split sec for controlling enrichment. BB headers with not so good wg piping for Tial 46mm and lowsy twin scroll flange. Tires are 315/35-17.
First pic is first to second with limiter banging so the rev sensor/log stalled. I had to blib before changing to second which also spinned.
From 930
This is fourth gear WOT just to see the spool. It would go up to 1.1 bar and then taper to somewhere 0.9 bar.
From 930
I might need to address that 3500rpm notch on fueling if it does not affect other areas.
MAP
From 930
79 930: HX40S#16, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, True split BB, 2*turbosmart38
Old 06-02-2014, 03:52 AM
Chain fence eating turbo
Mine does the same. It'll spike and taper down from 2nd through 5th. Nature of the Holset's turbines I guess.
Old 06-02-2014, 10:03 AM
