Porsche 930 RS Rennfrog
It's another story of a slippery slope and it's a long one. I don't want to spoil the journey by showing the result. So let's start at the beginning.
The car started as a nice euro 930 3.3l which rolled out of the factory in 1983. Like all 930 of this era, it came standard with a lot of options/accessories....
So we quickly started disassembling it, cleaning, and removing bits here and there...
Old 04-19-2014, 12:54 PM
jostein's Avatar
This is exciting, doing the same with my 79 930.
930 "rs" project
951 1986
951 upgraded 1987
Old 04-19-2014, 01:25 PM
Tilikum Turbo's Avatar
Gorgeous color.
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 04-19-2014, 05:12 PM
Brando
quattrorunner's Avatar
Ok?
The result?
You said the end result?
Turbo powa!
1977 911s. it's cool
Old 04-19-2014, 08:04 PM
The sunroof was welded in place. It was well done and it has not cracked since then.
The weight saving includes the casing/motor and hardware.
Old 04-20-2014, 09:30 AM
Once the sound deadener layer was removed, we also started to remove some electrical components that will no longer be of use.
Old 04-20-2014, 09:39 AM
Both doors fully converted to manual. It is not so much for weight saving but rather for simplification / and look.
Old 04-20-2014, 09:43 AM
And now the ugly... The body is absolutely rust free BUT a PO thought it would be smart to spray a rubber based protective coating in all compartments / wheel well / underbody. That thing is just horrible to deal with. We have tried all sorts of method.
And first we did the trunk.
Which first looked like that after our first effort (also note the RSR welded in strut bar)
Old 04-20-2014, 09:52 AM
I am trying to get larger images...
Old 04-20-2014, 09:55 AM
The body received further modifications : removal of front fender turn indicators, antenna delete. It was time for a new paint job, the first one...
Old 04-20-2014, 10:08 AM
IMR-Merlin's Avatar
Interesting. I kept the power windows in the doors so I could run the cage closer to the door panel.
I'll be watching this build.
Old 04-20-2014, 11:01 AM
yep, im slow in the head
carslutt's Avatar
Send a message via Yahoo to carslutt
hum........ so this is done and your doing a sort of time like of how the build went.
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something
Old 04-20-2014, 11:28 AM
Das Schnell Ei's Avatar
I like the swap to manual windows. What was needed to do the swap?
'77 911S Coupe 3.2 Turbo
'76 911S Coupe 3.0 964 cams...no sunroof
'75 911S Cabbie 3.2 SS Web cams & 46mm Webers
'73 914 1.7 Webers & Header ... sold
'74 VW 1303S 1600cc DP Web 110 & Solex
Old 04-20-2014, 08:05 PM
First you need to fully strip the door (and remove the window frame). Obviously you need a pair of manual regulators. They are not always easy to retrofit to more recent windows : the "rail" which is glued to the window has been redesigned in late 70s and the updated version will not fit on manual regulators. On my car, it was simpler to change the windows (I had a pair laying around).
If you want a true backdate look, there is another operation to remove the rotative locking system (77 on). You need to change the pull lever (taller on older cars to be operated directly by pressing on the button) and the locking buttons.
All in all, nothing difficult but a long job to do it correctly.
Old 04-21-2014, 07:37 AM
The AC system has been entirely removed down do the last hose/bracket/bolt.
On the body some welding was required to fill different holes in the front trunk.
[/quote]
Old 04-21-2014, 08:00 AM
Turn lights and antenna delete (on 83MY the antenna is still on the front wing)
Old 04-21-2014, 08:03 AM
At that point the car was re-painted in original platinum metallic. Sorry for the crappy cellphone pics...
Old 04-21-2014, 08:05 AM
The car was then brought to Rennfrog in the suburbs of Paris. This was a year ago. You can also have a glimpse at some of the modifications in the interior...
Old 04-21-2014, 08:09 AM
A preview on some of the interior changes
Old 04-21-2014, 08:14 AM
I like this. Looking forward to following along.
Old 04-21-2014, 09:28 AM
