gumba's Avatar
K27 turbo questions
I have a K27 7006 on the car. It came with the car, and I have no idea what condition it's in.
Is there anything I should check for?
Is there anyone who can rebuild/modify this unit.
Is there a better turbo option based on the engine specs?
3.5 twin plug
sc cams
SSI's
DP muffler & intercooler
cis
dynoed at 390 chp @ .9 bar
max power 6,000 rpm.
thanks
Harold
'79 930/DP935
'68 VW Turbo Crewcab
Old 04-25-2014, 09:26 AM
TurboKraft's Avatar
Hi,
We can rebuild it, we have the technology. We have the capability to make it better, stronger, faster than it was before...
Seriously though, your 3.5L could stand a lot more compressor wheel with no loss in boost onset.
Checking it: there should be no axial play, and minimal radial play. Check very carefully, very light effort -- press too hard with your thumb against the compressor nut, and you can bend the turbine shaft.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-25-2014, 10:21 AM
Turbo
Go to Chris and you will be in very good hands !
This fellow pelicanite knows Turbos and he knows what he is talking about in general.
With all the best from Krautland
Dirk
Old 04-25-2014, 02:32 PM
gumba's Avatar
What does the up graded compressor wheel provide?
Harold
'79 930/DP935
Old 04-25-2014, 04:43 PM
TurboKraft's Avatar
The larger compressor wheel provides another 22-25hp at the wheels -- tested on a modded 3.3L C2T running exhaust and 1.0bar boost.
That car didn't gain any turbo lag, and was only slightly less snappy rolling in and out of throttle on the highway. You probably won't see a drop in response because of your 3.5L.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 04-26-2014, 12:40 PM
