newbie
timspu's Avatar
Scavenge pump oil leak from body
I have an oil leak from the my scavenge pump. It has been previously re sealed.
It only leaks at high rpm basically when on boost. If the car is driven normally there are no leaks.
it looks like there could be a hair line crack in the cast.
Is this something that happens on these pumps?
I see JB weld is mentioned quite alot here, would this work as a temporary fix or atleast to see if it stops leaking.
A new pump is over 1000 pounds and there are no second hand ones available.
thanks for looking
TIM
Old 04-25-2014, 11:09 AM
There are aftermarket ones available cheaper than that and they flow more oil too. I swapped mine out as it couldn't keep up with an aftermarket turbos oil flow.
1987 930 - 935 Tribute
1971 911T w/3.2 motor
Old 04-25-2014, 11:24 AM
