Robbbyg's Avatar
Heres a question,
If AFR wasnt a problem and say for arguments sake you could get the air flow to zero degrees,
Would the bottle neck then lie in the compression it forces through the engine?
Wheels
Last row 1977 3.0 930 260hp built, still reassembling
Row 1998 996 MK1 3.4 296hp new daily driver
Old 04-27-2014, 02:17 PM
Crotchety Old Bastard
RarlyL8's Avatar
If by bottle neck you mean "what causes detonation under boost?" the ultimate answer is compression. Simplistically, you can safely add more boost with cold charge air, high octane fuel, and reduced timing. The opposite is also true. At some point the AFR must change to compensate as well, but that is beyond typical 930 engine mods.
Old 04-27-2014, 05:35 PM
