Starter wire on front fusepanel
Anyone know which fuse and position up/down the Yellow Starter wire connects to?
I ask because ive run out of test fuses as ive blown them all :( |
i did not think the start wire was fused.
your question is a bit confusing. you asked which fuse is for the start wire but you keep blowing fuses......... |
The yellow starter wire should go from the body plug behind the ignition switch/behind the brake booster directly to the starter. I don't believe it goes through the front fuse panel.
This wiring diagram shows the starter wiring (in red and yellow). There is no fuse in the circuit between the battery and the starter.
If you want a clear PDF version of this, PM me your email address. http://forums.pelicanparts.com/uploa...1398856829.jpg |
| All times are GMT -8. The time now is 03:23 PM. |
