gumba's Avatar
3.0 vs 3.3 turbo motor
Any advantage/disadvage between 3.0 vs 3.3 turbo motor? I've run across a 3.0 turbo motor for sale. Ultimate max c.h.p. would be in the 300-350 range. The stock i/c location is not going to work. So some type of aftermarket or custom i/c with either motor. This will bolt up to a '84 915 box. Is the 3.0 a direct bolt up, or do I need to go to a different clutch package.
Harold
'79 930/DP935
'68 VW Turbo Crewcab
Old 04-30-2014, 10:14 AM
TurboKraft's Avatar
Both will bolt up to a 915.
The 3.3L is 7:1 compression, so better drivability at your altitude than the 3.0L's 6.5:1.
3.3L also has a higher flowing CIS system.
Small difference in intake manifolds' throttle body angles.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-30-2014, 10:23 AM
Don't the row 76-77's have the higher flow fuel head too?
63 356 So Called Outlaw
76 930
Old 04-30-2014, 11:13 AM
Brando
quattrorunner's Avatar
I have the 3.0 bolted to a 915. Ask any questions you like.
I started with a powerclutch and it spun that pretty quickly with an andial intercooler and gt30r turbo.
Now I use a centerforce clutch and that holds the torque fine.
I have gone through one 915 gearbox though. On my second and looking for a g50 for the future.
Basically I love the little 3.0T. It takes a lot of verbal abuse but it's a great little engine and makes a screamer of a car. Look here:
Turbo powa!
1977 911s. it's cool
Old 04-30-2014, 12:40 PM
porche's Avatar
No not the 76 - 77 930 Turbo motors.
All '78 and '79 US (North American) and RoW 3.3 motors had the big cast iron fuel heads and non-Cat systems. I believe all RoW 930's from '80 thru ''85 were the same. If it is a street application, and dependent on where you reside, you may need to deal with emissions issues if the motor year does not match the chassis year???
1979 Indishrot 930, Rudolph
"Dad, buy it! Real race cars don't have sunroofs."
Old 04-30-2014, 12:43 PM
I was told back in the day by two reputable shops who did rebuilds on my 76 Euro that it had the higher flow heads. I think the guys at Andial said the same thing.
76 930
Old 04-30-2014, 01:46 PM
cover's Avatar
The 3.0 L. engine is about 25 kgs. lighter, has a shorter stroke, lower compression and sits around 30 mm. further ahead in the car due to the short bell gear box.
As far as I understand, the fuel head discusion applies only to 3.3 cars.
The 3.0 cars featured the same fuel head for all markets.
Ilse: 1976 Porsche 930, Black, w. Rarly L8 headers & muffler.
Daisy: 1963 Jaguar E-type FHC 3.8, Carmen red (sold)
Old 04-30-2014, 02:52 PM
gumba's Avatar
Which is the G50 of choice, 02?
Harold
'79 930/DP935
Old 04-30-2014, 05:35 PM
Brando
Old 04-30-2014, 05:52 PM
TurboKraft's Avatar
All the Carrera G50 boxes are awesome with a Turbo engine for street use.
Normally, the 1987-89 Carrera box is easiest to install.
But if this is for that other vehicle... you could also easily install a 1990-94 C2 transmission, or C4 one if you get a different nose cone (cover) and delete all the AWD stuff.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 04-30-2014, 06:19 PM
Robbbyg's Avatar
Ive got a 3.0 930 euro came from the factory without an intercooler
A PO swapped out the 4 speed for a later 915 Box
I added a 3.3 intake, BOV and IC to mine as it just missed the parts bin for the Intercooler they were introduced in late 77.
I rotated my throttle body to make the factory 930 IC fit and removed the big airbox in favour of a fabspeed air intake
Engine is Still all from Porsche except the air intake but i have more flow so im happy with it
A Major improvement is Boost safety and engin bay room as i also removed the aircon and compressor, The IC fitted without a hitch into the big tail, when i have my ignition sorted ill be increasing my spring to 1.1 bar, currently .8bar without the mods when i first got the car and without knowing i was running 1.2 bar springs she handled that, i guess it depends on the condition of your engine on the inside too.
Wheels
Last row 1977 3.0 930 260hp built, still reassembling
Row 1998 996 MK1 3.4 296hp new daily driver
Old 05-02-2014, 10:04 AM
lite75's Avatar
I'm running a g5001 in mine and you'll not believe how well these match up to the rev friendly 3.0. I would recommend adding a reinforced side cover and your good to go.
75 930, 76 930, 83 SC EFI turbo
Old 05-03-2014, 06:14 AM
Tilikum Turbo's Avatar
More grunt(torque) from the 3.3L is always good.
Center-force clutch/plate mated to the 915 has worked flawlessly.
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 05-04-2014, 07:28 AM
gumba's Avatar
Does the g50/01 use a hydraulic clutch? If so, did you convert to a hydraulic system?
Harold
'79 930/DP935
Old 05-04-2014, 08:28 AM
lite75's Avatar
Yes, change over to the hydraulic clutch. It's a easy swap if you get the parts from a g50 donor car.
Old 05-04-2014, 04:34 PM
