Boost Gauge Pressure Sending Unit Problem
Hello Pelican -
I am having an interesting problem. Since I've purchased my 930 in January, I've gone through two pressure sending units for the boost gauge. First one I put in lasted <100 miles, and second probably even less. Both work properly, then suddenly the boost needle gets stuck at 1.5 bar (77 Turbo Carrera). Luckily our host is awesome enough to warranty the piece... but is my car killing these pressure sending units? Of course, no fuses are blown because as soon as I plug a new one in, everything is dandy! Piece is Made in Germany by VDO. Host Part # 993-606-103-01-M100. First sending unit had reminisce of dap oil on it (blow by?), but nothing else major. Any guidance would be much appreciated. While I get the warranty work, it's annoying to keep sending things back and forth. Perhaps it's just a coincidence? |
Why not use a 2 bar gauge, then you won't be slamming the other one so hard it sticks?
By the rear fuse panel there is a 14 pin plug,
the Sender wire to the boost sender inside that plug is brown with white spots looking at the rear of the engine it will be the wire that is far bottom right This wire is fairly thin and only soldered into a round cap , over time the cap turns in its socket wearing the strands of the wire away and either shorting out on the adjacent wire inside the 14 pin plug or sending a weak signal o the guage,, or other problems, Some folk say to wiggle it and it comes good, ,, not good idea because every time its wiggled that wire loses another strand or two, |
I'll take a look at this wire when I get home. Hopefully this is the issue, however, I still can't explain why I have to replace a sending unit every time it shorts, or sticks at 1.5 bar. Thanks all for suggestions! |
If I recall, should a person pull the wire off the sender, the gauge will peg. The sender provides a ground path for that wire, so if the sender itself is poorly grounded you could get erratic gauge action (as in pegging to max whenver the ground is lost). This is especially true when the boost sender is mounted to the Intercooler, since the IC is pretty much rubber mounted.
If you suspect poor ground, then run a separate ground wire attached directly to the body of the sender. You guys will have to help me 'cause I don't remember precisely and don't have a sender to look at, but memory says there are two spade connectors on the sender. Perhaps one of them is intended as a separate ground point? You can also test your sender by removing it and applying air pressure, and with a VOM reading the resistance. The resistance should increase as pressure increases. If you need it, somwhere I've got the resistance values across differing boost ranges. You may very well have returned two perfectly good senders! |
Good point, Mark. But the IC must have a good ground for the overboost switch, otherwise the fuel pumps would never run, assuming the fuel pump circuit hasn't been modified to bypass the overboost switch. Hopefully the OP isn't using thread sealant on the boost gauge sensor.
SR 86 930 |
Good point on the thread sealant, by the way! |
Thanks again for the guidance. The car is a 77, so there is no IC. It sits on the manifold, and what you mentioned about the grounding problems do make sense. The only weird thing is that if it was a grounding problem, a new unit wouldn't make everything go back to normal, right?
It almost seems like the setup damages and breaks the pressure unit? |
so that part of your description has me stumped But if you want to check the cintinuity anyway Ive just resoldered mine but see the pic below where im pointing, if you take the black cap off the cover of the pin connector and test continuity from the brown wire straight to the lug on the sending unit youll find that youll have 100 percent -0 continuity and that is your problem, ive just done mine ive also got 1.5 bar on my Euro 77 and mine was always stuck on bout 1/4 bar then it went to 1.5 and sat there for a while.. now it sits squarely on zero after fixing the brown wire :) While your in there take a pic of BEFORE you start taking wires out if you decide to do the lot. Ive been awake all night because of another unforced error on my part :( http://forums.pelicanparts.com/uploa...1398993075.jpg |
To overcome that i use Loctite medium the light Red one, if used sparingly a good Ground is still maintained, That ob switch is a pain twice ive lost boost from it coming loose in the past :( |
Your sender should not fail. It's just a simple potentiometer that moves and changes resistance in response to the pressure it sees. The more resistance it sees, the higher the resistance and the higher the gauge reading. It is not under any + voltage, just the negative ground lead from the gauge is attached to it. So if it continues to give problems, most likely it has something to do with the wire from the sender to the gauge (cracked or broken wire, bad connection somewhere).
Here is the full range of the resistance readings of the senders, for bench testing, that I picked from a previous post of mine a few years ago. 0.0 Bar 5 - 13 Ohms 0.9 Bar 117 - 129 Ohms Of course you would have to take it off the car and put air pressure to it to see if the values are in line. Somewhere I have a complete mapping of resistance values for each psi |
The root cause should be found first as to what is the problem. |
Our sponsor sent out a new piece to me (second unit under warranty) and the unit died AGAIN. I have now gone through three separate VDO units, all failed. I don't understand why the units would die, since mark houghton mentioned that the unit was receiving no + voltage. Again, the boost pressure unit is dying, not the gauge itself. Every time I put a new unit in, it works for a few hundred miles then dies. Is it possible that something is getting into the unit itself? I'm stumped. Here is a video of the result, although it probably won't tell much: Boost gauge problem, Porsche 930. - YouTube |
Weirdness.....Put a voltmeter between the sender wire and ground; see if you have some voltage that shouldn't be there. I still feel that's nothing more than a ground connection but hey, I've been known to make mistakes and don't have an electrical schematic in front of me.
Here's another pregnant thought: It may be a fault with the gauge itself, drawing too many amps through that sender/variable resistor ground contact, and frying it as a result. Put an amp meter between it and ground, see what she's drawing. Just a long shot.... |
Without the boost pressure sensor, I measured voltage of the brown wire (that is supposed to attach to the sensor) to ground. I got a reading of 9V. In addition, I read the current to be 10Amps. Lastly, the boost gauge went to 0 when the brown wire was grounded. Measuring the source of the boost gauge to be 14.5V and using ohm's law, I deduced the boost gauge's resistance to be 0.55 ohms and the resistance of the "noise" that is causing a 9V drop at the brown wire to be 0.9 ohms. Knowing from the previous posts that a 0 Bar reading from the boost pressure sensor is 13 ohms. If this is the case, the 0.9 ohms that is causing the 9V reading isn't enough to cause the boost gauge to read max at all times. With the current (broken?) boost pressure sensor connected to the brown wire, there is a 14.5V reading where the brown wire meets the sensor and 0 Amps across it. This is the characteristics of the sensor being at high resistivity with low current, which in turns causes the boost gauge to peg at high. So it seems the boost pressure sensor is operating abnormally. There should have been 13.9V and 1A measured where the brown wire meets the sensor at 0 Bar and at with the resistivity given. Questions: 1. Obviously a 9V reading at the brown wire should have been 0V. The common ground seem to have some minute resistivity. Does anyone think this is why the boost pressure sensors are killed? 2. Is the 10Amps of current too high for the sensor (and causes the sensor to malfunction)? The original fuse in this circuit is 15Amps. That would be 145 Watts if the sensor was at 0 ohms at worse case. |
This issue has me pulling my hair, anyone? :)
Someone surely has to have a Boost Pressure Sensor killing 930! |
Hi where is the location of the Pressure Sending Unit for Turbo Boost in 1986 930?
the boost gage is stock in 1bar and it was working fin few weeks ago not is stock there some help please |
Max boost reading of OEM sensor
Anyone know range is factory boost sensor ?
1979 T I have a 1.4 bar spring and the factory 1 bar gauge in tach face - Thinking about external gauge or maybe have the tach changed by Palo Alto gauges if they do such a thing I am also wondering if I can attach two gauges to the sending unit - so the factory gauge will be operational and a 2 bar gauge will tell me whole story. I am really clueless with electrical - so my guess would be no. If I split the wire then each gauge would get half the reading ?? |
What is the other terminal for
I THINK the other terminal is for an external ground wire, though the good Dr. Porsche never included a wire to that location (I'm presuming that he presumed that the sender mounting point was a good enough ground by itself). It may come in especially handy for folks that have their sender mounted directly to their "rubber mounted" IC. Put an ohm meter between it and where the sender mounts and see if you get continuity.
Thanks to this wonderful forum, I diagnosed and fixed my boost guage brown wire in 15 minutes!
If we ever lose this forum, an awful lot of valuable info will go with it.
That is an understatement Mark! I read and use this forum all the time and it has helped me and many of my friends solve many issues that had us stumped. Rahl |
| All times are GMT -8. The time now is 02:53 PM. |
