LinkBack | Thread Tools | Rate Thread |
Update
Try advancing the timing.. maybe even one gear tooth on the distributor gear. You can always go back to where it was if thats not it.
What does it say if you use 'start pilot' ? It's cheap and one of the first things I will use to see what it does. Changing many parts is useless if they are just fine!
Another question you didn't answer, do you smell fuel after cranking? Try it and let us know. Last edited by klefroid; 05-15-2014 at 10:50 PM.. |
I even think it should start if one tooth,or if not you will have misfire's (and the car did not when it stopped running. For us it's a good thing to try but it's not always a good thing to try as some people are not as experienced with these cars. Using the flash light thing? Not sure how it's named in English? The you can see the same thing even better without changing anything that can give more issue's.
Did you check your CIS fuel pressures ? A clogged WUR could make the car way too lean and it wouldn't start.
If the control pressure is good and you hear the injectors when you press the metering plate, then your fuel should be OK. For the sparks, where did you check with your tester ? The stock Beru spark plug wires have threaded connectors and they can become loose. I would remove the wire from the coil to the distributor, put a spark plug in it, ground the spark plug body and visually check for sparks. If it's good, then check all the ends of the spark plug wires, make sure they're all the way in. A loose spark plug or coil wire could damage a CDI box or coil, and you said you had a bad permatune. Where are you located ? |
Smart quod bastardus
Is there any way to test the ignition switch without just replacing it? I am struggling with my own starting issues and have gone thru most of the other checks on the green wire and replaced relays, etc. but have not looked at the ignition switch or any wiring under the dashboard. My fuel system is completely rebuilt and the WUR too so I think something is cutting the spark momentarily when trying to start the car and once it runs for a minute or 2 it stalls and wont restart. Thanks, Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Fred i have never had an ignition switch problem nor removed mine was just making a suggestion as the ignition switch has created starting problems for other posters here. Sorry.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD |
Fred
Location: Central Coast CA, South Eastern WA, Bay Area CA and MAUI Hawaii
had the same thing happen to me on my 86 930 turned out to be fuel pump fuse connector to panel
86 930 turbo perfect 89 911 targa will be someday 95 surburban 180k and still love it 87 300d mercedes airport car Living Life Is...... Choices and Chances Make Some and Take Some |
So to summarise;
You have spark at the plugs. Not sure about the tester thing you mention - but if you pull a plug and hook into HT lead you get spark when you crank it? Each time. You have fuel - you have pulled an injector and watched fuel spray out - with key ON, plug at airplate pulled, and plate depressed? Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Wow...back to ignition switched. The simple test is fuse #12 in the truck (count from the front of the car) should be 12 v when the ignition is on. Mine was 0 volts, the fuse sends power to the rear main connector to power up the CDI. My CDI never got 12 v with ignition on, so checked voltage at fuse #12. Since no voltage at #12 I jumped a wire from fuse #11, this then powered the CDI.
Remember some voltage is switched on by the ignition switch...when the ignition switch is bad no voltage is sent to the switched powered, like power mirrors or windows, or CDI, radio, etc.. |
Update
Alan L, yes, there is spark. As far as I can tell there is fuel. I have not loosened an injector yet as they seem to be a bear to get to with the limited access. I have loosened the bolts at the fuel distributor and there is fuel.
My apologies as I have not had a chance to yet try other things people have recommended as I haven't had the time lately. When I depress the air metering plate the pumps run, what is interesting is that it makes a shrill, shrieking noise at first. Looking over the entire car i found the yellow wire connector to the thermo time switch broken off. I moved the pipe to the turbo out of the way and removed the thermo time switch. I then reattached the wire with the switch removed from the car and cranked the engine. The car stumbled to life for about 10 seconds - more than it has during this process. Would the thermo time switch stop the car from running? Ben |
![]() If you have a spark then it's your fuel. at least if it's strong enough and about right on time. |
You only need to be able to lift one of the injectors. 4&5 aren't too bad to get at. I would want to be sure there is fuel squirting out of an injector at the point the car won't start.
Alan
klefroid, sorry I missed your question earlier. Do I smell fuel from the exhaust after cranking? Not really.
Fuel wise I've checked the flow at the filter and it's good, I've tried both relays and they work, both pumps seem to be active based on the sound and there is fuel if I loosen a bolt on top of the fuel distributor. On first start up it will catch occasionally - yesterday by running a wire to the thermo time switch to hook it up properly it ran, stumbling for about 10 seconds. Ben |
If one fuel pump would fail then I don't think your car would die straight away without any response? Not sure (I had it one's (front) and my car brought me home) Is it possible for you to check your fuel pressure? Even if it's hard to get to a fuel injector,try to unscrew one. reconnect, stick it in a bottle and push the air plate under the air filter housing. See what it does. Last edited by klefroid; 05-27-2014 at 12:56 PM.. |
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification. |
if you have spark, my 930 had a bad fuel pressure regulator.
Update
After spending considerable time working on the car my son and I found and diagnosed a potentially bad thermo time switch, a bad fuel pump relay and a bad yellow over boost relay.
The thermo time switch was merely unplugged on one side with a broken wire but we replaced it out of caution and age. Now the car will start and stumble to life, run for about 10 seconds and die. Sometimes there is a smell of fuel in the back other times not. Fuel flow is as it should be based on the test where we filled a graduated beaker. Is it now the speed relay under the seat? Is there a way to jumper the speed relay to test before trying to find one? I can't seem to find one anywhere for sale. Thank you all again for the help. Ben |
Thread Tools | |
Rate This Thread | |
