Robbbyg's Avatar
Originally Posted by Tilikum Turbo View Post
Your lead-in to the question "are wrong" and then proposing a "view" is a disconnect in logic.
Thanks for the compliment Tilikum
I knew at least one person here would see it my way
Wheels
Last row 1977 3.0 930 260hp built, still reassembling
Row 1998 996 MK1 3.4 296hp new daily driver
Old 05-09-2014, 09:22 PM
Banned
Originally Posted by Robbbyg View Post
HAHAHA bugger ive been found out
Actually its not too bad ive actually inadvertently installed a 4 point floaing suspension system for my relay panel, its completely unaffected by bumps..
yeah theyre all jealous of my inventiveness
Ha, that's too awesome Rob, and I'm glad you've got a sense of humor about all this!
And you know what, I've finally figured out what that extra "b" in your screen name represents - BUNGEE, of course!!!
Old 05-09-2014, 09:36 PM
Chain fence eating turbo
OK i know I'm going to get a lot of negative feedback here. But here goes. For a forced induction engine equal length headers are useless. The fact that there is a turbocharger in the line causes back pressure which negates any scavenging effect of having the pulses of each exhaust valve opening and closing being lined up. The best bet for a forced induction set of headers is the smallest volume ie shorties length possible to reduce turbo lag. Now there is an exception for the twin scroll versions since the sides have to be balanced to take advantage of it. I have talked to a few people who have actually tested this on a dyno and they confirmed what i was thinking. Equal length headers are designed for normally aspirated motors so that the exhaust pulses line up behind one another ans they flow into the collector. This results in a vacuum scavenging effect in the primaries and increased flow through the exhaust valves. Any way chose to believe it or not but if there really was anything to gain by equal length headers on a turbo motor all of the factory race teams would have used them. Instead they went with shorties on the 935's and also later turbo 3.6's etc.
I can't simplify this enough for my logic that equal is better.
If 2 or more cylinders exhaust pulses/energy with unequal length primaries roughly arrive at the same time in a collector or T flange, how can the energy NOT be negated?
Both or more pulses are trying to occupy the same area reducing gas energy. With perfect cadence, the pulses would have an easier time passing through the tubes/collector.
Not saying I'm right, it's just my logic with zero fluid dynamics background.
Old 05-09-2014, 09:42 PM
Robbbyg's Avatar
That sounds logical to me , its what i was trying to say in original post when i mentioned firing order, but it is more of the order (sequence)? of gases that arrive at the collector T Flange thing,
On this Logic At the point of gases arriving in that area the collecter should be very large ? that would allow all he gases to pass without slowing down to where they go to?
After the collector If they were tapered down (in morphed cube shape ,Maybe?) to match the size of the Turbo opening, If the least disruption is ideal then header shape can be improved ie: round to Square?? (note if anyone does this it was my idea )
Not discounting I think Mr Rarly has done great work (your welcome)and studies and he has many facts to back it up, i think however there are areas that could be changed to make a better system or are we at the point of 100 percent perfecton already?
I did a drawing to show what happens as Tippy says see below
Wheels
Old 05-09-2014, 10:45 PM
Robbbyg's Avatar
Originally Posted by quattrorunner View Post
It's not the same time if the engine has a fireing order.
Actually thats right i think?
So theres that area to consider..
If engines dizzy is spinning around and sending spark to each cylinder then the gases at cylinder 4 (depending on rotation) are waiting to be sparked he is last in line something to think about also?
Wheels
Old 05-09-2014, 10:50 PM
Robbbyg's Avatar
Originally Posted by Maltese Falcon View Post
Everybody buy some u-bends, j-bends, and straight sections from Jegs or Summit.
Start putting together some various headers like;
equal length, pulse tuned length, 180 , tri-y, 6 into 1. Then build all of these one more time, but in step-tube sizes.
Then lets install and run on the dyno for comparisons of rwhp/Tq.
Keep in mind that forced induction engines push exhaust gasses around different from n/a engines, yet another variable in the design criteria.
Lots of work ahead of us !
Marty
I actually would do that but ive only got 4 inches of pipe left over from when i made my Custom Tapered up-pipe from silicone ,and 8 inches pipe from a Ford V8 (and Wait for it!)) A cable tie)
plus i might need to know how to weld, Im another that cant weld , something ill have to learn when i get a roof DAM
Wheels
Old 05-09-2014, 10:56 PM
Banned
No need for welding skills - just cable tie that bit@h in place!
Old 05-09-2014, 11:34 PM
Smart quod bastardus
fredmeister's Avatar
Originally Posted by RarlyL8 View Post
I did a fair amount of header research when designing our equal length 930 headers. Conventional wisdom at the time was the shorter the better. Turned out that was only half the story. The full story was the shorter the equal length the better. What true equal length primaries and secondaries do for you in a turbo application is allow the engine to produce more torque off boost and then to produce more peak power on boost. This is in a street application mind you, racing is a whole different ballgame. I dyno tested every system I could get my hands on using the same engine. The equal length system is magic. The tuned sound alone was worth the effort. The key is for each pulse to reach the turbo in the same timing as the firing order, not a mish mash of odd fire pulses. Each pulse hits the turbine in a coordinated efficient beat.
Building short tube headers is easy and gives you a high percentage of gain over standard heat exchangers. I would not have gone to all the effort and expense to build a tuned system if it had no added benefit. This is not a new or unique idea.
Brian,
Can you post some of your results for torque and hp that you validated when testing your equal length headers against other designs such as the B&B or OBX headers that alot of us have installed on our turbos?
I like to see testing and want to see the gains since you went thru the trouble of doing back to back tests.
Could you post a few dyno graphs for us here?
Shouldn't be too much trouble I hope.
thanks,
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 05-10-2014, 05:34 AM
Quote de Tippy
The exhaust is not CONSTANT, it's PULSING.
With, I assume, a bell curve in velocity and CFM from start of each pulsing event until stop.
But again, never took fluid dynamics as an ME has.
Old 05-10-2014, 07:44 AM
Crotchety Old Bastard
RarlyL8's Avatar
Turbos produce power using heat and velocity. Heat is easy, it is velocity that I fucus on. This is covered well in Corky's book. The primary internal diameter must be matched to the ports and the application. Too big and you lose velocity (increase lag) but increase top end HP capacity (huge turbo airflow). Match the primaries to the ports and you optimise off boost torque and reduce lag. We use merge collectors to further optimise the flow transition toward the turbo. The path is continually restricted until it reaches the turbo flange where all the energy is focusted.
I have posted dyno graphs of short tube versus tuned headers when we were testing these headers. Controlling boost creep was thrown in the mix as well due to the poor design of the elephant nose waste gate circuit of the short tube headers. That muddied the water a bit as more boost equals more power. I'll look up the graph.
Old 05-10-2014, 07:45 AM
non-whiner
mreid's Avatar
For purely testing purposes and low cost, I've found that PVC pipe and duct tape make the best rig.
Just mock it up, tape it up, and make a dyno run. Easy, quick, and disposable!
Works awesome!!!
Of course, then there's Brian's method...
"Too much is just enough."
Old 05-10-2014, 07:51 AM
Works awesome!!!
Why use such costly materials for the experiment? I prefer paper towel and toilet paper rolls and cost effective scotch tape.
Oh, and forget a flowbench, I found a child's pinwheel works just fine for reading velocity.
Old 05-10-2014, 08:45 AM
jsveb's Avatar
I assume we all agree that two major factors are important. Lengt of runners and equal length.
While from, a scientific perspective, this is a fact, we operate under certain constraints, so we have to compromise, I think Brian can confirm this during his testing. By compromise, I mean it is not possible to achieve the shortest possible headers, while also being equal length. The result of this is that the longer runners required to achieve equal length somewhat take away the benefit ( note I did not say remove, just negatively affect) to what degree is beyond me. The key piece from this is, both considerations are valid, however, reality is a compromise. This compromise (or rather optimization) is where the money is made.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 05-10-2014, 09:03 AM
[QUOTE=Robbbyg;8057139]On this Logic At the point of gases arriving in that area the collecter should be very large ? that would allow all he gases to pass without slowing down to where they go to?
If they were tapered down (in morphed cube shape ,Maybe?) to match the size of the Turbo opening, If the least disruption is ideal then header shape can be improved (note if anyone does this it was my idea )
Good thinking, sort of like this? Norwood build, circa 2002. Also I think the 935 header was very similar. So i think a patent is out of the question.
Anthony @ Voitureltd Bayside WI.
Old 05-10-2014, 11:17 AM
I can assure you this set up has no noticeable turbo lag
Now with 2 tial 50MM wastegates. No more "uncontrollable" wheel spinning waste gate malfunction.
Old 05-10-2014, 11:53 AM
[QUOTE=voitureltd;8057691]
First time I've seen that one. Looks like it works well from the dyno print out.
Changing oil looks like it makes a mess on the heat exchanger under the drain plug.
Old 05-10-2014, 01:37 PM
jsveb's Avatar
I am not sure I understand your logic, but if I do. When the gases merge into a smaller area, the gases do not slow down, they speed up.
Jesper
Carrera 3.0 1975
Old 05-10-2014, 01:47 PM
7.0:1 > 11.3:1
This topic is exhausting.
Old 05-10-2014, 01:53 PM
Banned
Yep, lots of "hot air" being blown about!
Old 05-10-2014, 02:03 PM
Yeah, my "primary" thought is to do a "header" off a 3rd floor. But, due to the "velocity" of getting ready for Mother's Day, I've "spent" my "gasses" leaving me too "exhausted" to do so.
I hope we all "merge" our thoughts of this topic into our precious forum that is essentially a "collector" of opinion and loosely scientific facts.
But my "secondary" thoughts are that there is something to learn here I believe....
Old 05-10-2014, 02:29 PM
