Selecting turbo based on pre-determined boost level?
Tippy made an interesting post in Rey's EFI Mistress thread about modern turbos working better or being optimized at higher levels of boost. Rather than take that very cool build thread OT, I thought I'd start a new thread. http://forums.pelicanparts.com/8057420-post81.html
Yep, maps are everything.
Read Garrett's turbo tech; it explains it all. Squirrel Performance has a built in calculator you can play with too that's pretty fun. The turbine side is harder to figure. Compressors are pretty cut and dry. Meaning, balancing response to peak airflow/hp parasitic loss is a little trial and error on the turbine side. |
