jsveb's Avatar
It might just be me, but i think you guys are being blinded by the vast knowledge you have got, and are overcomplicating this -- probably poorly worded -- question.
For many, this would be somewhat simpler by merely stating what turbocharger one has, and then proceed to explain.
I understand why Chris and also Brian may find it difficult to answer, simply because of the fact they have made so many different configs. over the years. However, for some of us who have got only one turbo slapped on at a time, it should be possible to list the turbo, brand, size, config etc, and then layout engine specs and why you made the choice you did, and then describe what performance characteristics it resulted in.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 05-20-2014, 08:48 PM
gumba's Avatar
I'll give it a shot. Some constraints at the time of the engine build in 2009. Ca. car which had to pass emission & visual inspection.
K27 7006. Was on the car when I bought it.
3.5 Mahle w/stock compression
sc cams
12 plug distributor w/twin cdi boxes
stock heads
stock cis, wur, with all smog stuff in place & working
SSI's
DP intercooler
DP muffler
Tial wastegate
390 fwhp @ .9 boost at around 5500 rpm ( I'll dig out the spec sheet) on J.W. engine dyno
Turbo Kraft just did a complete overhaul on the turbo. Not able to do any mods because it was an old style 3 bolt. Got to try it out today after the 50 mi. break in. Much better, but how much if any h.p. was added I can't tell.
The motor was originally built by Andial. At the time of the J.W. rebuild I wanted to stay with the old school theme and retain the original parts. One of the previous owners had installed JE pistons using Mahle cylinders. We swapped those out for a new set of Mahles.
Harold
'79 930/DP935
'68 VW 3.3 Turbo Crewcab
Old 05-20-2014, 10:28 PM
xbmwguy's Avatar
Ken I wanted to do what u are planning on doing just dirt rocks etc changed my mind. Once done I really like outcome
Old 05-21-2014, 04:01 AM
xbmwguy .... that is a sexy rear!!
Old 05-21-2014, 04:30 AM
Ken911's Avatar
I'm going to build a box behind it to house the filter to keep rocks dirt and water out. I saw another thread on here where it was done to a set of upper rear fender vents on a car that had twin turbos. I think they were made by K&N. Any one know what the inlet size is on a gtx67?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 05-21-2014, 06:01 AM
Chain fence eating turbo
I focus on 2 key factors when trying to figure out what I want:
1. Boost onset
2. Peak hp
Unfortunately, I have to read Supra's and the 4-cylinder crowd to judge by.
So, a Supra is smaller but has the turbo much closer to the exhaust ports making for a decent comparison with our engines. Not perfect, but useable data.
If a 4-cylinder engine has great boost onset, I know our engines will easily spool the same configuration turbo.
Old 05-21-2014, 07:32 AM
jsveb's Avatar
Gumba, those are nice numbers. I wish I was up there, but hardly.
My turbo is a K27 "powerhaus". Once I get my car back I will post as well.
Btw, I have a HX40 (with a billet comp wheel) and a small turbine housing I want to try out. Unfortunately this accident has cost me a six month setback in a busy 18 month period, so I prob won't get it installed, along with a se to BB header I scored for cheap, before I travel back to Denmark after my 4Y stint in the US.
Xbmwguy, it LOOKS FANTASTIC!
Jesper
Carrera 3.0 1975
Old 05-21-2014, 08:18 AM
Crotchety Old Bastard
RarlyL8's Avatar
> K27-7200
> 930/63
> Euro Distributor
> Euro CIS
> SC Cams
> RL8 Intercooler
> Stock 0.75bar Boost by 2700rpm
> RL8 Headers/Muffler
> 360whp / 360tq
> K27-7200
> Same engine only Euro Heat Exchangers
> Stock 0.75bar Boost by 3100rpm
> 300whp / 310tq
The turbo is only one aspect of performance and it's characteristics are very much altered by the other components of the build.
Old 05-21-2014, 07:23 PM
jsveb's Avatar
Thanks Brian.
Yes, i see an engine as a system comprised of interdependent parts. Change one and the output will be different. The same could be said for the IC or cams as other have mentioned. This does not change the fact that it is still relevant to study these individual component, while realizing it is all interdependent, hence cannot be isolated and necessarily transferred to a different engine (system) and expect the same output.
Jesper
Carrera 3.0 1975
Old 05-21-2014, 07:56 PM
lol.. a plug for his headers. Heck I'd buy some if I could afford them.
Back to turbos, this Borg Warner one looks pretty good but it's not a bolt on. Looks like it might work with some silicone hose adapters and a v-band muffler connection modification and the overstock blowout price with free shipping is attractive.
Borgwarner Airwerks S360 S300 83 75 88 A R Open Scroll Turbocharger | eBay
Old 05-21-2014, 08:08 PM
gumba's Avatar
What a difference the exhaust makes!
Did you do any mods to the cis
Harold
'79 930/DP935
Old 05-21-2014, 08:24 PM
RarlyL8's Avatar
The exhaust allows the turbo, and everything else, to work.
That is what I was testing so that is the data collected.
Yes fuel curve and ignition were dialed in very well, not much left on the table.
Anyone who has tried different turbos on the same engine should chime in; having an established baseline will give useful info.
Old 05-21-2014, 08:47 PM
jsveb's Avatar
I have looked at those as well. I am not too concerned with them not being plug and play, but the T4 flange do bother me some, I'd prefer to stay T3 on that aspect.
I'd would love to try one of their smaller models, just to see how quick a response I'd get.
On occasion there are some really sweet custom ones on ebay, by the sound of it anyways.
Jesper
Carrera 3.0 1975
Old 05-21-2014, 08:49 PM
They might have them with T3 hot side housings but probably not at overstock clearance prices.
Old 05-21-2014, 09:21 PM
Brando
quattrorunner's Avatar
I have a system like #2 but mine is a 3.0turbo.
Plus garretson inter cooler. And I have a gt30r Garrett gt3076r.
My choice was for quick spool which I feel the bb is slightly overrated but I do have pretty quick response. I have no baseline as this is the only turbo I used(other than a holset very briefly) but my response is as follows:
Fifth gear (915/61) 1000rpm I have posative pressure, full .8bar by 2750rpm and solid shove all the way from there with no noticeable loss ever. (Up to 6krpm)
In normal driving over 3500rpm the turbo feels connected to the accelerator. Instant response, maybe not as quick as hypo itb na engine but really responsive. No real lag.
I like it. I'm installing water cooling for the jacket and I'll be happy.
Turbo powa!
1977 911s. it's cool
Old 05-21-2014, 10:04 PM
jsveb's Avatar
What are the specifics of your turbo? I'd like to know how it compares to the HX and BW
Jesper
Carrera 3.0 1975
Old 05-23-2014, 02:42 PM
Brando
Quote de quattrorunner
Specifics as far as wheel dementions and sizes I really don't know.
.84 on the turbine I think and 61 or so on the compressor. I believe is what I remember. But I don't understand maps and what the sizes and trim really does.
I buy, bolt on and then hope it all works.
The Garrett works, the holset felt fine but there was something wrong with it as it failed quickly. So I antied up and bought a new chra from Chris at Turbokraft since he gave me a killer deal on the replacement even though I munched the original turbo by dropping something inside the compressor pipe.
When the new turbo was still clean and shinny it overpowered my .8bar spring to 1 bar. That was fun.
Old 05-23-2014, 02:57 PM
