Lower intake needed
I'm working on an '87 930, it has had several mods over the years.
I'm trying to turn it back to stock.
Looking for this pipe/T, or a completed lower manifold.
If you have one, please send price or I have a modified one for trade
Thanks,
Jon
Old 06-02-2014, 12:38 PM
Banned
Jon, that piece could easily be reproduced - you could take a picture or drawing of it, including dimensions for the size of tubing you want used, to a plumbing or hydraulic shop and they could make it no problem. Of course, you could make it yourself if you solder.
Old 06-02-2014, 12:44 PM
I was thinking about using some 1/2" copper pipe, just being lazy and hoping to get one already to go.
Old 06-02-2014, 01:26 PM
Alan L's Avatar
The brass nipple you have looks like it will be threaded. The original part from memory is a press fit with some glue stuff. So I don't think an original part will fit in anymore. You are better to find/make a Tee with same thread as must have been tapped into your manifold.
Alternatively, get a whole new manifold.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-02-2014, 02:24 PM
TurboKraft's Avatar
I should have several Y-tubes, will look.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 06-02-2014, 02:27 PM
