sjf911's Avatar
I think you could easily do a monster motor with MS2, the real benefit of sequential is at low load.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 06-05-2014, 07:29 PM
Chain fence eating turbo
Thanks, Tippy
I will assume that the MS variants up to MS3 are then fairly suitable for street/some track/low boost applications such as mine, where absolute HP is not the objective. And, the non-sequential injection will not need cam sensor?
Absolutely. Keep the injector sizes down, and idling MSII should be really smooth with nice low speed drive ability.
Old 06-05-2014, 07:43 PM
Only reason I'll go III in future.
Old 06-05-2014, 07:44 PM
Mike Billings's Avatar
Just to clarify the MS3-PRO variant (above) drives up to 8 injectors on the first bank (stage). I use low impedance injectors, each with a resistor wired in series.
It has two more drivers for a second bank of injectors.
As stated above, there are modes for engines with no cam sync sensor installed (batch). You can change modes whenever you want, or add a cam sync sensor later.
When I added the Clewett Cam sync sensor months later, suddenly I had boost in first gear. Never had that before using batch fire. I have no explanation for that. It just runs much smoother with better mid-range torque.
Also, you mention horsepower. There are maps where you can control injector timing based on load and RPM. As I understand, there's a little bit of horsepower hiding there.
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Bridgestone RE050A
73 911E - Hoosier R6 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 3+
Old 06-05-2014, 07:46 PM
