dos531's Avatar
Where to get shims for system pressure?
Anybody know where to get the shims to adjust the system pressure? I see pelican has the whole kit, but its about $100 and all I need are a few shims.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'01 996tt
Ducati 748R
Old 06-09-2014, 01:47 PM
Smart quod bastardus
fredmeister's Avatar
I used a small washer that I found from a kit of washers that matched the OD of the system pressure relief valve spring. It does not have to be an exact machined shim.
Works for me fine.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 06-09-2014, 01:59 PM
Ken911's Avatar
get the rebuild kit it has shims in it.
928-110-920-01
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 06-09-2014, 04:47 PM
Or you can go to a U-Pick junkyard and get them off another CIS system for probably for free.
Old 06-09-2014, 05:06 PM
dos531's Avatar
928-110-920-01
Yeah thats the one thats $100...dont feel that one coming on just for a couple shims.
'01 996tt
Ducati 748R
Old 06-09-2014, 05:18 PM
jbrown's Avatar
Just shimmed mine yesterday. I took one of the shims and went to home depot and they had the exact size in a pack of 4 for 50 cents...
Old 06-10-2014, 05:41 AM
Ken911's Avatar
when i took mine apart it didnt have any small shims just one thick one. But my fuel head was one of those modified onse from imagine auto. So when i needed to raise system pressure I bought the kit put in the new needle valve and replaced the o rings plus the additional shims to raise the pressure.
Old 06-10-2014, 06:42 AM
Alan L's Avatar
If you have a selection of washers, and some shims already in there, you can usually juggle the shim/washer combo to get exactly what you want, ie use a washer to delete a bunch of shims, then add these shims as required. That way you don't need more shims. Alternatively you could make some out of shim plate - with suitable metal punches. You may have to buy the punches, but less than $100 and you get to keep them.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-10-2014, 10:31 PM
