Robbbyg's Avatar
Need Help with Fuel Lines
Hi Need some expertism,
I want to replace the fual hose from the WUR to the Fuel Head
and the long fat one from the Filter to the Fuel Head
Normally i would order replacements from the host but due to distance i need them quicker than they can get here. As ive had a problem with them
So can someone help me in sizing i want to replace with ones off of Ebay the AN type, i just watched a Utube clip and the fittings seem easy to DIY
So when ordering AN what do i need?
Do they have the same size and type of nut to screw into the head?
Do they have correct diameter for the WU
I dont know about conversion or the lingo used,
Can anyone post exact details on what to order to replace those two lines
I know some will point out that im going Aftermarket and curse
well its for a friend of mine
He uses an aftermarket Intake too !
Ive highlighted the two replacements im needing do i need to replace the nuts at the ends as well?
Wheels
Last row 1977 3.0 930 260hp built, still reassembling
Row 1998 996 MK1 3.4 296hp new daily driver
Old 06-09-2014, 04:31 PM
oilonly's Avatar
I would email BoxsterGT for those lines Robbert. When i relocated my WUR i purchased the two fuel lines going from the WUR to the fuel head through him, no issues.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 06-09-2014, 04:53 PM
You could try a local hydraulic hose supply store or go to your airport and check with the aircraft mechanics and find out where they go for that kind of stuff. Aircraft hoses are top quality and usually dated so there's no old dried out stock sitting around.
Old 06-09-2014, 07:35 PM
jsveb's Avatar
Do yourself a favor and don't mess with DIY AN ebay parts on fuel lines in the engine bay. Especially if you are in a hurry...
I highly recommend boxsterGT as well.
Step back and think about how much in a hurry you are. Not enough to compromise on this issue.
Get a tested product from a reliable source and spend some more money on expedited shipping instead.
My 2C
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 06-09-2014, 08:40 PM
Robbbyg's Avatar
All Good i took my hoses and went to a quality hose place and got a metre of Polymid hose spent all night putting it on the Banjos before getting successful,
In the end i soaked them in boiling water, wrapped them up in tape to protect them , tied 3 pencils around them to keep it straight put it in the stilsens for grip and held down the banjo with the vice before getting them one, Dont want to do that again extremely difficult task that one.
Wheels
Old 06-10-2014, 04:53 PM
TT Gasman's Avatar
Before you do any aftermarket hoses, try ordering directly from Porsche. I was surprised that I could get all the parts I needed when I replaced the entire set of lines on my car.
Old 06-11-2014, 07:06 AM
