BlkBird's Avatar
Blkbird lives!
My precious Blkbird has close to 100,000 miles on her and the other day she suddenly decided to start blowing white smoke at idle. Not just a little white smoke, no, a lot of white smoke. Think hiding the car from prying eyes smoke screen.
After a few calls and gathering of opinions, I took Blkbird to Graham Everett Motorsports adjacent to Road Atlanta. After all, the guy owns a 930 so he must know old turbos. Well, it turns out he sure does.
The white smoke was coming from the modified K27-7200 turbo. Apparently it was so fouled that it was a wonder it actually spun. But... we also discovered the rockers were badly worn and the valve guides kind of shot. No wonder it felt like I was towing a load of cinder blocks before.
So we decided to give the engine a full refresh.
  • New valves and valve guides.
  • 964 camshafts.
  • Rocker arms
  • Valve guides and valves.
  • Turbo repair
  • Clutch
  • Reface flywheel
  • Pull jugs and re-hone cylinders for new rings
  • RarlyL8 Hooligan exhaust with center outlet. I know, totally unrelated to work at hand but what the heck.
Just got the car back today so I'm trying to be gentle. But holy bat poop she sure hauls bootie! And that new RarlyL8 exhaust is everything I'd hoped and heard it would be.
Watch out for future updates, and hopefully no speeding tickets. Special thanks to Brian and Graham for all their work and efforts. Very nice!
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 06-11-2014, 02:35 PM
sweet Chris! I knew you missed her. Can't wait to hear it on boost.
Old 06-11-2014, 02:43 PM
Alan L's Avatar
Did you regrind your 930 cams to 964, or did you fit 964 cams - looking at same process. very optimistic after your posting.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-11-2014, 03:42 PM
BlkBird's Avatar
We used 964 cams. Mine were not fit for regrind.
Old 06-11-2014, 04:15 PM
How fantastic to have basically a new engine at 100K miles and get ready for the next 100K. I'll look for you flying by with the top down on 400 next time I'm down there!
Old 06-11-2014, 06:47 PM
Location: Rehoboth Beach, DE summer - Indian Wells, CA winter
My car has 66,000 and runs great so any engine rebuild is (hopefully) way down the road. However, I'm curious as to ball park cost for the rebuild you did.
Thanks!
Old 06-12-2014, 06:11 AM
BlkBird's Avatar
Just south of $10k.
But my rockers were shot and the cam needed replacing. And of course while the engine is out is the perfect time for a clutch. And while the heads are off lets check the cylinders & pistons, then hone them for a refresh.
You get the idea. One thing just naturally progressed to the next...
CH
C.H.
Old 06-13-2014, 07:55 AM
Pm sent
Old 06-13-2014, 11:57 AM
Non User
infraredcalvin's Avatar
What, no pics?
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
'75 914 GT clone project
'71 914 track car
Old 06-13-2014, 06:19 PM
930T Owner
Hams930T's Avatar
As a friend once told me.... Pics or it didn't happen!
Hams930T
1986 930
2015 991 GT3
2016 Cayman GT4
2012 911 Cup
Old 06-13-2014, 06:21 PM
MBAtarga's Avatar
Blkbird is too fast for pictures!
Mark
'83 SC Targa - since 5/5/2001
Old 06-15-2014, 12:40 PM
BlkBird's Avatar
Tough audience!
I'll take some snaps after I finish filling in the holes left in the rear valence from the old exhaust. I used to run a dual outlet GHL but I'm fond of the center exhaust look.
Anybody want to buy a gently used GHL? Only used on Sundays to get to church,
CH
C.H.
Old 06-15-2014, 02:23 PM
Robbbyg's Avatar
question,
Can 964 cams be installed in a home garage? they sound tempting
Wheels
Last row 1977 3.0 930 260hp built, still reassembling
Row 1998 996 MK1 3.4 296hp new daily driver
Old 06-15-2014, 04:02 PM
Alan L's Avatar
They can be installed if you have the tools and enough enthusiasm to do a partial top tear down = cam timing etc. Engine out job really - not worth trying to leave it in.
The issue is if they are straight 964 cams they will need a bit of modification first because the 930 drives the scavenge pump of the LH cam and the 964 doesn't have this fitting. (Hope I'm right on this - going thru same exercise).
Alan
Old 06-15-2014, 11:29 PM
Originally Posted by BlkBird View Post
Tough audience!
CH
just take the valance off chris. what did you do w/ the WG dump pipe?
Charles
79 930 #632
88 911 Cab
74 TR6
88 CRX Si
Old 06-16-2014, 09:46 AM
Oheggem's Avatar
I got the hooligan too and it sounds perfect. Pics and or vids are required though
Old 06-17-2014, 02:18 PM
BlkBird's Avatar
Charles,
Went back to short dump pipe under the car. Just need to splatter weld in some sheet metal and then replace the valence. That or RarlyL8 has a fiberglass replacement part that is tempting.
C.H.
Old 06-18-2014, 11:47 AM
