Backdating '76 930 to original non-intercooled setup, what should I change?
I have a German market '76 930 in Copper Bronze Metallic with plaid interior. It is mostly original with only 62,000km. It was upgraded about 8 years ago to GHL headers, K27 turbo, Garretson long neck intercooler, and Tial wastegate.
Thank goodness the previous owner kept all of the original non-intercooler charge pipes and parts, and I have the early Turbo tail in the right color. I plan to keep the headers, K27, and Tial. I thought it would be fairly simple to just remove the intercooler and put the original parts back in, but nothing is ever that easy. :) Questions: 1. Will the k27 and Tial wastegate work OK with the original charge pipe (non-intercooled) system? 2. The Garretson intercooler has an overboost cutoff switch (that cuts off the fuel pumps), but there is no bung for it that I can see in the original system. Does the original system have a different way of overboost protection? 3. The blowoff valve was external with the Garretson, but it is inside the aluminum housing in the original system. I don't understand how that one works...it doesn't appear to need any hoses connected to it to operate unlike the current external one. When I remove the external blowoff, do I just cap off the plumbing for it or does it somehow need to be re-routed? Thanks for your help! |
Pics please;-) and some showing the interior too!
I know it is not what you are asking, but unless you want to sell the car, I would keep it on there, IC etc., that is. It won't do your engine any good to remove, on the contrary. One day if you decide to sell re-install the original parts.
I'll be doing a photo shoot for it very soon similar to what I did for my '66: https://picasaweb.google.com/107462596126098920364/1966Porsche911SlateGrayRedInterior# |
The stock charge pipe to the throttle body does get a vacuum signal to operate the recirculation valve, pull the piston open. Vacuum from the top of the intake manifold, to the left of the throttle body.
Someone who drives his 1976-77 930 will enjoy that Garretson IC and factory 1978-89 wing. |
Thanks Chris.
What about overboost? Do I just eliminate the overboost cutoff system entirely? All original cars fetch the most money at auction, but will provide the Intercooler and '78-89 tail with the car for the new owner to enjoy. |
There is an overboost switch, it's number 24
http://forums.pelicanparts.com/uploa...1402965415.jpg |
Regarding what you should change, well first and foremost, your mind (unless you like going way backwards with performance, that is)!!!! :D
Do I attach the vacuum line to the waste gate (which used to attach to the intercooler) to this port? It's hose 42 in the parts diagram above. http://forums.pelicanparts.com/uploa...1402973541.jpg What is this port on the back of the bypass valve supposed to connect to? It's hose 43 in the parts diagram above. http://forums.pelicanparts.com/uploa...1402973608.jpg Thanks again. |
a workshop manual might be useful--check the links at Porsche 930 Turbo Carrera 3,0-liter
Thanks...I did look there but there's no vacuum line diagram to go by and the instructions for removing and replacing those parts don't mention where the lines go.
Here is a picture of an early intake manifold. I tried to mark vacuum hoses, its not great, but here you go.
Hose #1 large diameter hose for brake booster Fitting # 2 Hose attachment to BOV hose is about 8'' long and is routed under the manifold Fitting #3 short hose to Vacuum limiter goldish canister Hose # 4 vacuum to distributor pod Hose # 5 to wastegate Fitting # 6 vacuum line to vacuum limter nipple on the front http://forums.pelicanparts.com/uploa...1403029700.jpg |
*perfect* Extremely helpful...thank you so much Stevie...that solved all my problems! The collective knowledge on Pelican never fails to blow my mind!
Having some cold start issues. The auxiliary air regulator (#44 on the parts chart above) connected to the inter cooler before, bit now it has nowhere to go. Where does hose #48 connect on the 3.0 cars?
I've seen the hose go back by the throttle body in the pics online, but I can't see where exactly. Does it connect to the large nipple on the back of the intake manifold to the right of the throttle body? You can see it in Stevie's photo but a vacuum line kinda blocks he view. Thanks again for your help. |
http://forums.pelicanparts.com/uploa...1403271337.jpg
I don't quite remember where it goes by the throttle body, but that nipple you mention seems too much of an angle the wrong direction, this photo is from a very dirty disassembly... I'll be at it this weekend, maybe I'll post a link of all the photos I have on a share so you can peruse through... |
There is a intermediate block with a hose nipple, the block is between the manifold and the cold start valve. AAR hose attaches to it.
i would sell it as is with original parts.
coming from someone that was looking for an original 930 within the past few years, having the extra "goodies" on there would not be a negative. in fact more of a positive. that would just save me having to take the original parts off and put the go fast stuff on there. the key is that it CAN easily be made original. i have done some wiring changes on my car but you cant see it and it can easily be put back. |
Thanks Chris, I will look for it there.
T77911S, that was my original plan, but with the stratospheric prices these 3.0 Turbos fetch lately, they are likely to end up as garage queens rather than drivers, and original appearance is what that crowd wants. I hope that's not the case with my car as it's a blast to drive, but that's the reality IMHO. |
You are testing my lack of skills using paint......
Here you go.....(but remeber this is for a 77 with a Aux Air Valve that is used for cold start) This what mine looked after i pulled it duriing an engine rebuild I too removed a intercooler from my 77 A line to Aux Air Regualtor # 44 in parts diagram B Vacumm control for WUR on the top of WUR (assuming you are using a 022 or 050 WUR C boost enrichment line to WUR D Cost start valve (blue device) E used for Aux Air Valve on my 77 F vacuum line to Decel Valve (see previos post) G vacuum line to EGR Valve http://forums.pelicanparts.com/uploa...1403289449.jpg This is what my manifold looked like after a good cleaning and neww lines http://forums.pelicanparts.com/uploa...1403289212.jpg |
Thanks again Stevie...just what I needed. This will be a great thread for others who want to backdate later on...I won't be the only one.
The wastegate has a lower hose that as I undestand goes before the intake into the intake tube, and the upper port as I understand vents to the air. Any pictures of this connection? Thanks Ivan |
as pictured # 5 hose goes to wastegate lower line. As you state the top of the wastegate vents to air
http://forums.pelicanparts.com/uploa...1502829068.jpg |
Stevie
Can you post some pictures of that engine all around? It will be great reference Ivan |
Wow that is some engine porn right there! Gorgeous work Steve!
This thread bump brings back a lot of memories. Although I sold my Euro '76 930 non-sunroof for a lot of money 3 years ago, I sure do miss it. More pics: https://goo.gl/photos/g8KBjKuWovTaT6cs9 http://forums.pelicanparts.com/uploa...1503073018.JPG http://forums.pelicanparts.com/uploa...1503073018.jpg |
Thanks stevie, great information. I might be sending you some more questions if you don't mind. I am in the process of doing the engine work.
I am not doing a 100% back to stock. I kept the headers, and left the air pump out for now and I am still debating on the need to add the stock BOV. http://forums.pelicanparts.com/uploa...1503242001.jpg |
The stock BOV works perfectly well and i wouldn't delete it. As you know it integrated into the up and down pipes. If you are referring to the decel valve, that too, when woking correctly serves a good purpose. Here in California, without the air pump and EGR, i wouldn't pass the visual smog test, but I do get by with W-pipes vs thermos.
Your engine is looking good ! |
I am not doing the emissions parts for now. I will problably gather the parts over time just to have them but I do not need them for my inspections.
What I am referring to is the part circled on the picture below. I do not have it, don't know what it does and not sure If I get one how will I install the hoses if the car does not have the emission components. I refer to it as BOV, but not sure if accurate. All turbo carreras I have seen are not using it, some have it delete ans some are just sitting there. Any suggestions? http://forums.pelicanparts.com/uploa...1503281433.jpg |
What have " circled" is the control valve and what you " X" is the diverter valve. You are correct, not needed if you are not using the air injection system.
In case you want to know what these do: The control valve is boost activated and measures a certain amount of pressure and then sends that pressure to the diverter valve, opening the diverter valve to divert air away from air injection system during boost conditions. |
I have those parts somewhere in my garage.
This info is gold, thanks again so much Steve!
| All times are GMT -8. The time now is 02:50 AM. |
