bmwtmx's Avatar
Full Load Cold Start Enrichment Comensator?
I was told the full load cold start enrichment compensator needs to be cleaned but I have no idea what this is. I tried searching but to no avail and I was told my car needs this part cleaned.
Anyone know what this is, where it is, and how to clean?
Old 06-18-2014, 11:39 AM
Crotchety Old Bastard
RarlyL8's Avatar
Full load and cold start should never be used in the same sentence, let alone part description. In CIS the WUR performs these separate functions. By coincidence the cold control pressure and the boost pressure can be the same number.
Old 06-18-2014, 11:46 AM
bmwtmx's Avatar
Ok. I was told my car under cold conditions is running lean and this part, the one I noted, needed to be cleaned. Now I was told there are 2 WUR's, one for fuel, one for air/idle. My problem is fuel whereby the car is running lean when cold so it sputters until warm. Can I clean this? Any DIY? Is my guy just confusing things?
Old 06-18-2014, 11:49 AM
T77911S's Avatar
sounds like you need to forget what you have been told and find another guy
the WUR has control pressure for warm and cold.
the pressure is lower when cold to make it run richer. as it warms up, the control pressure goes up makeing it lean out for normal HOT running conditions.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-18-2014, 11:59 AM
bmwtmx's Avatar
Wonderful. Can the WUR be cleaned, does it need to be adjusted, or replaced? How do I test this?
Old 06-18-2014, 12:05 PM
RarlyL8's Avatar
A worn out WUR will run lean when cold commonly. You can decrease the cold control pressure (enrich the mixture) by pressing in the cold mixture plug on the top rear of your WUR. There are good write ups on the specifics in the archives.
Old 06-18-2014, 02:39 PM
oilonly's Avatar
Two threads for you to read.
WUR malfunction repair?
Want to raise boost AFR - I have a WUR adjustment question
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 06-18-2014, 04:54 PM
bmwtmx's Avatar
Much appreciated. My car takes about 10 minutes to get to full operating temp which I just thought was normal. I will have a look.
Old 06-19-2014, 11:30 AM
