-   -   Engine is in but clutch not working !!! (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/817145-engine-but-clutch-not-working.html)
klefroid 06-20-2014 01:04 PM
Clutch is not working after putting the engine back in... I'm pretty sure that the fork was in the right place. This is a pain in the ass...
It feels good at the pedal but when I press the clutch pedal nothing happens!
I've try-ed to tighten it up but even then no luck! Why did Porsche made this so difficult.
Anyone any idea what this problem can be? Is there anything I can try before pulling out hte engine again!? :mad:
klefroid 06-20-2014 01:57 PM
Probably I have to get the engine out again. May be my last shot. Those cars are assume but they are just not fun to keep them in a good working shape. I've been thinking of just selling the car and buy something els that give me more fun and less stress.:(
gsxrken 06-20-2014 02:34 PM
Few things are as frustrating as having to back up and redo something. It sure sounds like you did not line up your clutch release fingers properly with the throwout bearing.
It should be the first thing anyone reconnects/checks, before proceeding to reconnect everything else, just in case you have to rewind.
quattrorunner 06-20-2014 02:34 PM
This is one of the easiest cars to replace a clutch in. Engine comes out in less than two hours. in in the same. Clutch replaced in 35 minutes.
I had the same problem a couple years ago and it pissed me off too. Ended up being the release for out of place for me.
klefroid 06-20-2014 02:50 PM
It's strange that the fork got out of it's place because I am pretty sure it was in the right place. It is easy to take out the engine indeed but I'm just saying for the fork and clutch adjustment. I've seen more easy systems...
Thanks for your help guy's! knowing I was not the only one with this issue.
When I bought the car about 6 years ago it was in a very bad state. all original but it all had seen it's time. Now after all those years I was exited to finally get it all working proper but nope... A bad experience is also an experience so in the end I will know how not to do it or to double check.
jwasbury 06-20-2014 02:56 PM
sorry man...it is frustrating, but it also not very difficult to check if the release fork is properly engaged with the throwout bearing before plugging the engine/trans back into the chassis.
Sounds like you buggered it this time...look on the bright side. I bet you'll never do that again.
speaking of frustrating, I just had the pleasure of greasing my polybronze bushings again last night. The fronts are easy, but the rears are a pain in the @$$. One of the zirc fittings just refuses to accept grease, and the stuff just goos out all over the place. The parts work fine, but the maintenance is messy, and a pain. I'd not use them again were I to do it over.
Ken911 06-20-2014 06:30 PM
I always check in the vent hole to make sure the forks are aligned correctly. I also grab the spline on the fork shaft and try rotating it. I have had the same issue myself. It's a real pain having to drop it all over again.
JFairman 06-20-2014 06:57 PM
If the springplate polybronze bushing grease fittings are in the right positions there is a type of fitting for a grease gun that makes them really easy to grease without any grease leaking past the side of the grease fitting anywhere.
I got one at harbor freight and put it on a $9 one handed grease gun I also got there and it works great every time.
I can't describe it other than you pull back on a ring and you can turn the end of the grease fitting thing on the end 360 degrees at any angle possible, and when you release the ring it locks in place.
I have a couple pictures of it somewhere. If I can find the folder they are in I'll post it.
Kozmo930 06-20-2014 07:04 PM
Dude it just happened to me... but I was lucky caught it before install :rolleyes:
it happened to me last year in and out 3 times swore it was lined up , you do learn from mistakes .
Kozmo SmileWavy
16Volt 06-20-2014 07:09 PM
Going backwards in the final steps of any big project is miserable. This should make you feel better:
I was completing an engine swap which had taken 4 days solid of 10-11hr days. I had two things left, a distributor bolt and the bellhousing plug (VW 16V). I fumbled the bolt and down into the transmission it went. LeBron James couldn't have hit that shot. Had to partially drop the motor and pulls the trans....yeah. From that point further I never removed that plug unless I was timing the car.
We are with ya man.
JFairman 06-20-2014 07:17 PM
I found the harbor freight grease gun pics I was talking about above.
The tip rotates around and locks in place when you release the pull back ring.
There are other positions it will lock into in between straight or 90 degrees like in these two pics.
It's a well made grease gun and it works perfect for doing this with one hand. The whole thing was about $12.
I use a soup spoon to put swepco grease into it from a larger tube of grease than the smaller tubes that fit in this grease gun. http://forums.pelicanparts.com/uploa...1403316579.jpg
http://forums.pelicanparts.com/uploa...1403316595.jpg
klefroid 06-21-2014 12:46 PM
Ok guy's,
I checked the fork which is in perfect place! https://www.youtube.com/watch?v=DGs_l8WwdhY
I do know what causes this issue I think.
When I installed the flywheel I notice that it was oxidation because it was outside.
So Ive used a little bit varnish spray!
Damn that was stupid because now my clutch plate sticks to the flywheel... and it's not coming off whatever I do. I did not try to drive the car. Maybe there is a possibility that it pops of the flywheel.... never taught varnish could stick so hard!
quattrorunner 06-21-2014 03:32 PM
Yeah drive it. Push the pedal in and start it and see if it pops loose when you try and start it. Make sure no one is in front of you:eek:
klefroid 06-23-2014 08:32 AM
So guy's,
I drove the car yesterday and with the clutch pedal to the floor in third gear and I was able to let it slip. But still the clutch isn't working.
I took a snapshot from the vid I made and there is something that isn't right.
Should the release bearing been sitting wrong? That's what I suspect but not sure.
There is nothing els that I can come up with...
Thanks guy's for helping me out (again).:D
http://forums.pelicanparts.com/uploa...1403537534.jpg
JFairman 06-23-2014 08:48 AM
That looks like a lot of moly grease slinging out of your throwout bearing. If it gets on the pressure plate and disc it's going to slip all the time.
You can take apart the throwout bearing and clean out the old grease with solvent and then inject moly grease in between the ball bearings with a grease needle on a grease gun but get too much in there and it will fly out from centrifical force like it looks like that one has done.
dap930 06-23-2014 09:28 AM
Here is a picture of my Centerforce pressure plate with the throwout bearing in place on my '77 Turbo.
http://forums.pelicanparts.com/uploa...1403540326.jpg
Yours looks like it is installed properly. I think you may have to remove the small lever on the bottom of the transmission and jump it one spline to get some more adjustment. How much of the adjustment bolt is protruding through the small lever? It should not be much. Just a thought. Also, Are you using all stock components? Some of the aftermarket disks are not the correct thickness.
911nut 06-23-2014 10:35 AM
I've had my powertrain in and out 4 times in the last year and one half; turns out two drops were unnecessary.
Once you have the clutch issue fixed and the car running, the pain will subside :D
klefroid 06-23-2014 12:43 PM
Thanks for the reply's, but still looking for my aswer...
I been searching for what can be the issue of my clutch problem.
I'm trying to make it clear with onother picture because sometimes my english is just not good enough to explain my question....
So there are 3 arrows. I have set the bearing in place shown by the red arrow. I think this was not right. I had to loosen the bolds of the pressure plate to get the throw out bearing in place and tighten it up again. Is this wrong? please say yes! :(
http://forums.pelicanparts.com/uploa...1403552627.jpg
JFairman 06-23-2014 12:55 PM
The widest part thats behind the blue arrow pulls on the fingers of the pressure plate spring.
Looks like thats how it's in there in your first pic.
gsxrken 06-23-2014 01:24 PM
If I recall correctly, once it is installed, it is captive in the pressure plate fingers, and has to be held in the proper relationship as you snug up the ePP bolts. It sort of clicked in and couldn't fall down towards the flywheel.
These pics probably don't help but it's all I have from my first drop:
https://lh5.googleusercontent.com/-8...o/IMG_0824.JPG
https://lh6.googleusercontent.com/-f...o/IMG_0825.JPG
zcoker 06-23-2014 03:12 PM
Originally Posted by klefroid (Post 8130373)
So guy's,
It looks to me like the bearing is out and not in place behind the clutch fingers and is pulling on nothing. It's too close to the transmission -- too far forward on the guide tube with hardly any travel space left. Bummer.
klefroid 06-23-2014 10:48 PM
So it seems it was at the right place. To see the travel on the fork you need to see the vid I made. Because this picture is only a snapshot.
Engine is out again so I will take enough footage this time.http://forums.pelicanparts.com/uploa...1403588903.jpg
klefroid 06-23-2014 11:20 PM
Originally Posted by dap930 (Post 8130440)
Here is a picture of my Centerforce pressure plate with the throwout bearing in me on my '77 Turbo.g]http://forums.pelicanparts.com/uploads23/throwout+bearing1403540326.jpg[/img]
It's an upgraded stock. It was in the car before so that should be fine. I had the small lever at the maximum. thanks for the picture to
911nut 06-24-2014 04:48 AM
+1
That bevel retainer ring is supposed to be on the other side of the fingers.
dap930 06-24-2014 07:39 AM
After looking at your picture and looking at my removed throwout bearing, I believe your throwout bearing is not installed correctly. The throwout bearing is installed from the driven plate side of the pressure plate and the pressure plate fingers are captured by the throwout bearing groove. When you push the clutch petal down the pressure plate fingers are pulled towards the transmission. In order to install it as shown, you would have to slide the throwout bearing on the transmission guide tube prior to mating up the transmission. Normally the throwout bearing is held in place by the pressure plate so when you mate up the transmission, the guide tube engages the throwout bearing as the transmission seats with the engine. The thing that threw me off was the fact that you said you were able to get the clutch to slip.
Ken911 06-24-2014 08:44 AM
Yeah when you bolt the pressure plate on you have to make sure the fingers get captured in that groove. It tries to fall out until the bolts are snugged up on the pressure plate.
JFairman 06-24-2014 08:53 AM
Just took a couple pics of a used but good 930 throwout bearing I have.
It shows the groove the spring fingers go into well. The blurry low resoloution and glare on the picture the original poster has makes the bevel on the smaller flange a little more difficult to see.
The larger diameter flange is the one that pulls on the pressure plate spring fingers releasing clamping pressure on the disc as you press in the clutch pedal.
It still looks like his was installed correctly to me but there's too much grease on it.
http://forums.pelicanparts.com/uploa...1403625170.jpg
http://forums.pelicanparts.com/uploa...1403625181.jpg
911nut 06-24-2014 09:42 AM
Here's the resource that I used to install mine on my 964 Turbo: CLUTCH T/O BEARING INSTALL at LINDSEY RACING - Your Porsche Performance Parts Center
Maybe the 930 bearing is different.....
dap930 06-24-2014 10:22 AM
JFairman,
How did get the seal off the throwout bearing to clean and regrease it?
JFairman 06-24-2014 12:09 PM
It's been a while since I did it but there is a thin steel ring around the end that is in a groove. That ring holds it all together. I used a machinest scribe to pry the end of the ring out of the groove and lift it up and then I put a very small flat blade screwdriver under it to keep it from popping back into the groove.
Then I used the scribe and another small jewelers flat blade screwdriver to carefully and slowly pry the ring the rest of the way out all the way around until I could pull it off without bending or breaking it. If you're mechanically inclined you'll figure it out while looking at it and doing it.
Then the ring with the rubber seal comes off.
Then I soaked it in mineral spirits swiching it around every now and then to dissolve the old grease and I blew it out with 120psi compressed air. Then I sprayed brake clean in there and blew it out with compressed air until all the old grease was out and it was clean.
The t-shirt I was wearing at the time has never looked the same since...
I bought a grease needle at advance auto parts for about $3 that fit into the end of my little grease gun that was filled up with swepco moly grease. It looks like this one.
http://forums.pelicanparts.com/uploa...1403636582.jpg
While the grease seal ring is off the throw out bearing you can see the ball bearings inside and insert the grease needle in between them and inject grease in there.
Then I put it back together.
klefroid 06-24-2014 10:55 PM
It was due to that little bit varnish spray. So the clutch was stuk ont the flywheel.
I'll never use that again! It was only to prevent corrosion while sitting outside but forgot to take it of first... Stupid I knowhttp://forums.pelicanparts.com/support/smileys/wat5.gif
I need to take off the flywheel as wel, little leak there.
