-   -   G50 release fork problems (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/817446-g50-release-fork-problems.html)
totle 06-22-2014 02:34 PM
Had clutch failure this wee and it turned out that the release fork boss gave up.
http://forums.pelicanparts.com/porsche-911-technical-forum/817445-g50-release-fork-boss-failure.html#post8129420
Anyone with similar problem ?
Maybe with stage 2 PP, load is too much without reinforcing ?
911nut 06-25-2014 04:13 AM
One of the guys over on Rennlist had that failure from a mis-positioned throw-out bearing. The ears rotated out of position during the engine-transmission mating process and he didn't see that. He got the shaft through the release arm, stepped on the clutch and broke the bosses.
totle 06-25-2014 05:01 AM
Hi Paul,
In my case I suspect the extra force from the KEP stage 2 pressure plate that is the main reason.
Also the holes was mashined bigger for the newer type release fork axel. This cause the boss the get weaker as it is less aluminum to withhold
911nut 06-25-2014 09:48 AM
I bet it might have broke from a combination of the two.
Can you get it repaired in Norway or are you sending it over here?
totle 06-26-2014 08:42 AM
I picked it up from the welder today.
Was not the easiest alloy to weld, but should be good now
