-   -   Tail light housing/fastener help please (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/817493-tail-light-housing-fastener-help-please.html)
16Volt 06-22-2014 07:25 PM
To make a long story short I am trying to find a new housing and the housing to body fasteners. There are multiple part numbers listed by our host....
My housing on the backplate lists:
911.631.404.31
Pelican (and Sierra Madre) shows for 86 930:
901-631-942-00
They also list for 87-89 Carrera (they list the same part number for left and right side as well):
911-631-404-35
I think i need the housing since the cover screws corroded and snapped.
<a href="https://www.flickr.com/photos/looneys_on_the_lawn/14485537655" title="IMG_7067 by Shannon, on Flickr"><img src="https://farm6.staticflickr.com/5581/14485537655_45c8e739ab_b.jpg" width="1024" height="683" alt="IMG_7067"></a>
These fasteners are also too corroded to be salvaged. Any idea where to get replacements?
<a href="https://www.flickr.com/photos/looneys_on_the_lawn/14484306962" title="IMG_7070 by Shannon, on Flickr"><img src="https://farm4.staticflickr.com/3906/14484306962_6ebc8cf3c6_b.jpg" width="1024" height="683" alt="IMG_7070"></a>
They slip over the tabs in body and have a captured nut with a nylon lock.
Thanks for any help...getting pretty sick of everything on this car being corroded.
a930pilot 06-22-2014 08:01 PM
FWIW - I went though that last year and was able to have a machine shop tig a stud to the snapped bolt. The heat helped loosen it up enough to get it out.
I also happen to have a housing w/cover that they came out without problem, but the spring terminal for one of the bulbs broke off the housing. I was going to take a bulb socket and imbed it in its place, but never needed to use this housing. If you get desperate, let me know.
16Volt 06-22-2014 08:11 PM
Thanks man, glad I am not the only one.
I think by the time i find a shop to try to tig it I would be out about the same money as a new housing. Plus there's nothing really to weld to, the screws snapped flush with the housing post. ugh.
Is yours a passenger or drivers side housing?
16Volt 06-22-2014 08:51 PM
After more sluething I found a thread with details on the captive nuts, added below for any other hapless idiot who embarks on replacing their taillight seals.
http://forums.pelicanparts.com/porsche-911-technical-forum/451961-any-tips-successful-removal-tail-light-assembly.html
The captive nuts are here:
Pelican Parts - Product Information: 999-507-312-12-OEM
a930pilot 06-23-2014 03:44 AM
Drivers side.
16Volt 06-23-2014 07:12 AM
Bummer, well when I break that side I will send you a PM. :(
Anyone have any idea what the correct part numbers are for the housings?
PcarPhil 06-23-2014 08:22 AM
If you're still looking I may have a pair of housings from an '87 Carrera that I could part with. I've seen numerous housing from numerous years and don't recall any differences between any of them, so I don't know why they have different part numbers. I could be wrong though.
Let me know and if needed I'll dig them out of storage.
16Volt 06-23-2014 08:51 AM
Thanks Scott, PM sent.
PcarPhil 06-23-2014 06:01 PM
Here are some pictures for you:
This first pair I believe came from an '85 Carrera. Unfortunately there is no part number anywhere on the housings to confirm this. These are pretty nice, no/minimal corrosion, need to be cleaned, and have the harness plugs pushed back into the housings.
http://forums.pelicanparts.com/uploa...1403570777.jpg
http://forums.pelicanparts.com/uploa...1403570820.jpg
http://forums.pelicanparts.com/uploa...1403570850.jpg
http://forums.pelicanparts.com/uploa...1403570880.jpg
This other pair I believe came from an '87 Carrera. One of them has part number 911.631.404.31 (same as your '86). This pair is a bit dirtier, one of them has some corrosion on the rear cover, and one harness plug has to be reinserted.
http://forums.pelicanparts.com/uploa...1403571014.jpg
http://forums.pelicanparts.com/uploa...1403571035.jpg
http://forums.pelicanparts.com/uploa...1403571070.jpg
http://forums.pelicanparts.com/uploa...1403571097.jpg
http://forums.pelicanparts.com/uploa...1403571124.jpg
It's entirely possible I have the years of these housings swapped. In other words the second pair may be from the '85, and the first pair from the '87. I'm not 100% sure but based on what the internet is telling me about the 911.631.404.31 part number this may be the case.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
