klefroid's Avatar
Originally Posted by jsveb View Post
Adjust the idle to about 13-13.5 AFR, using the O2 adjustment on a completely warmed up engine.
Regarding ignition, I believe it depends on what type of engine, effectively your distributor, and what fuel grade you run.
Do some more research in this, but I think (from memory) somewhere between 26-29 degrees is safe.
Once you got your idle and ign sorted, it is time to tune the WUR. This involves either getting it modified or buy an adj. unit.
Fourth edit :
While this is not Porsche specific, it gives a good understanding of the importance of tuning your engine properly:
Engine Basics: Detonation and Pre-Ignition by Allen W. Cline
Thank you Sir!
Old 06-29-2014, 12:00 PM
jsveb's Avatar
No problem
On my engine, 78 930, I measure and adjust the ignition advance at 4k rpm with vacuum advance disconnected.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 06-29-2014, 12:45 PM
klefroid's Avatar
Originally Posted by quattrorunner View Post
My car is screwed up too.
You should have 12/1 full throttle or thereabouts.
There is more response and power higher 10/1. Your problem is the lesser of two evils I commonly see lately with modded cis cars though. Better yours than the ones that get too lean.
Got it now set at idle on 13.9 (had it set first at 13.5 but changed after test drive. Cruising at 12.1 and full acceleration 11.1 ... need to adjust the wur?
Old 06-29-2014, 01:37 PM
Brando
quattrorunner's Avatar
That's not perfect but it's pretty good. You could get an adjustable regulator and get better but it's not bad if you ask me.
Old 06-29-2014, 02:28 PM
Brando
What's it at 75 mph?
Old 06-29-2014, 02:29 PM
klefroid's Avatar
In 2nd gear?
will look tomorrow because it's almost midnight
Old 06-29-2014, 02:32 PM
Brando
Quote de quattrorunner
In 2nd gear?
No third and fourth if you use 930 box. Just cruising light load.
Old 06-29-2014, 02:34 PM
Whats going on with your oil pressure?
Old 06-29-2014, 05:13 PM
klefroid's Avatar
Is it to low then? not sure what others get but ,I see pressure and the more rpm the more pressure..
Old 06-29-2014, 09:39 PM
Might be your sender, but above 1,800rpm my needle is at "5"
Old 06-30-2014, 03:17 AM
Chain fence eating turbo
75PSI of oil pressure by 1800 RPM? That seems excessive.
Old 06-30-2014, 08:58 AM
jsveb's Avatar
It looks like you got more than 1bar/1000rpm. This seems excellent. I don't understand the 5bar above 1800rpm. This does not seem normal from my experience.
I would say your oil pressure looks good.
Old 06-30-2014, 09:00 AM
klefroid's Avatar
Thanks for the confirmation!
Old 06-30-2014, 10:39 AM
klefroid's Avatar
Hope it is for you because to much pressure could be made by another problem in your engine.
At least thats what they say in other threads.
Old 06-30-2014, 10:47 AM
Hi Guys
Question for you guys that have installed the Borg Turbo, is there a mounting plate off the hot side of the turbo similar to the K27? Thinking of order one, want to make sure there are no surprises.
J
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 57lbs. Cobra Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 07-18-2014, 01:51 PM
klefroid's Avatar
Originally Posted by jpilcher View Post
Hi Guys
J
There was no 4 bold outlet available. At least not for mine.
Old 07-19-2014, 07:58 AM
