Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average.
Really taking shape, Rod!
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3 w/MS3X, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 10-21-2016, 05:35 PM
  Pelican Parts Technical Article Directory    Reply With Quote #261 (permalink)
Thank you sir.
I'm super happy with the way things are progressing.
I just went through your build again, gorgeous stuff. I like the fuse panel and COP info too.
Rod
"This Year ferrari's Ass is Mine"
Old 10-22-2016, 12:04 PM
  Pelican Parts Technical Article Directory    Reply With Quote #262 (permalink)
Thanks!
I need to get back in the garage and post some updates. The harness, relays and fuses are all tested, loomed and wrapped with Coroplast and came out pretty well. The gas tank is done, and I just need to finish the dual pump mount.
1986 911 Turbo
Old 10-22-2016, 03:40 PM
  Pelican Parts Technical Article Directory    Reply With Quote #263 (permalink)
Cool, can't wait to see it. Just to let you know, I will be copying what I can
Rod
Old 10-22-2016, 06:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #264 (permalink)
Old 11-02-2016, 09:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #265 (permalink)
Old 11-03-2016, 07:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #266 (permalink)
Aviation holes in an effort to lighten things up.
Old 12-03-2016, 09:02 PM
  Pelican Parts Technical Article Directory    Reply With Quote #267 (permalink)
Turbo Powered Snow Blower
Any up dates?
Derrick
Old 01-30-2017, 08:47 AM
  Pelican Parts Technical Article Directory    Reply With Quote #268 (permalink)
Rod,my pro street 55 buick highway patrol car is like that holes drilled in the frame rockers every bracket,heck even the door hinges.I personally didn't do it,but it seems to be holding strong.I wanted also to say they cut most of the inside door out just leaving enough steel to keep a door pannel on
Sent from my SM-N910T using Tapatalk
Old 01-30-2017, 10:21 AM
  Pelican Parts Technical Article Directory    Reply With Quote #269 (permalink)
Hi Kevin
That is super cool. I don't know if I will go to that extent. Such a heavy car with light holes, love it!
Not much to report, I'm gonna Pick up the bumper today, had them sprayed with high build primer.
Old 02-04-2017, 11:02 AM
  Pelican Parts Technical Article Directory    Reply With Quote #270 (permalink)
I know,the car is freekin swiss cheese,also the whole front end is fiberglass including the grill&the bullets.Rod cool keep plugging away on that monster...
Old 02-04-2017, 11:12 AM
  Pelican Parts Technical Article Directory    Reply With Quote #271 (permalink)
Back from the body shop in primer, more sanding coming up.
Old 02-05-2017, 08:24 AM
  Pelican Parts Technical Article Directory    Reply With Quote #272 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
VZ935's Avatar
Send a message via AIM to VZ935
Looks great Rod!
A bunch of old race cars
Old 02-05-2017, 11:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #273 (permalink)
Rod, with that seat protector element to the cage, is there any concern as to what would happen if the car were nailed right where that bar is, pushing or folding it into the occupant's left thigh? I'm absolutely no expert, but it seems like it would help in a light to moderate hit, but could cause extra issues under a heavy side impact, like if you spun or slid the car into a phone/utility pole and took the impact where that bar is. Not being critical, just wondering. Best regards, John in CT.
Old 02-16-2017, 04:24 PM
  Pelican Parts Technical Article Directory    Reply With Quote #274 (permalink)
TurboKraft's Avatar
Liking this build!
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 02-21-2017, 01:05 PM
  Pelican Parts Technical Article Directory    Reply With Quote #275 (permalink)
closer
Thank you gents.
I was at the shop today, she was basking in the sun longing to hit the open road.
We are getting closer now maybe a few weeks and all the fab work will be done.
Old 02-21-2017, 05:57 PM
  Pelican Parts Technical Article Directory    Reply With Quote #276 (permalink)
I decided to torture myself, starting into sanding off the black anodizing and then polish all the window mouldings to a chrome like finish.
Old 02-21-2017, 06:06 PM
  Pelican Parts Technical Article Directory    Reply With Quote #277 (permalink)
Aircraft stripper makes this portion easy.
Old 02-22-2017, 08:00 PM
  Pelican Parts Technical Article Directory    Reply With Quote #278 (permalink)
How goes it Rod
Old 02-25-2017, 03:20 PM
  Pelican Parts Technical Article Directory    Reply With Quote #279 (permalink)
Yellow Zinc
Hey Kevin
Doing good, how about you anything new and exciting?
That aircraft stripper works great, I just need to pick up some more and finish the mouldings. Meanwhile I organized all the nuts bolts, screws, brackets, etc. for yellow Zinc plating and some chrome plating items too.
Old 02-28-2017, 04:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #280 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
