LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average.
rear coil over supports
"This Year ferrari's Ass is Mine"
Old 08-16-2014, 07:41 PM
duct tail coming along
Old 08-16-2014, 07:44 PM
some more today
Old 08-17-2014, 07:22 PM
Surprisingly easy, I got the rear suspension bits off, 935 here we come.
Old 08-17-2014, 07:33 PM
Some more progress today!
Old 08-24-2014, 05:43 PM
7.0:1 > 11.3:1
Your work looks great. Question, what the heck are doing to that engine shroud?
edit: I built a similar splitter on my old 930 and picked up on the outer most front torsion bar mount bolts. The bolts are canted at a bit of an angle as you noticed while doing your pan rebuild, but a couple bushings and longer bolts took care of this.
Old 08-24-2014, 07:26 PM
Thank you Jim
The rear oil cooler is replaced with 993 oil console/filter. So we are flattening it out, the duct isn't needed.
Old 08-24-2014, 07:33 PM
Jim that's a good idea.
I might add a flat stainless steel tow hook/ring off of those front suspension bolts too.
Old 08-24-2014, 07:42 PM
knocking down the mold lines etc.
Old 08-26-2014, 06:02 PM
steering damper
Old 08-26-2014, 06:05 PM
Looking good!
I took the easy way out and got the non-oil cooler shroud from Damon Josz @ Series 900.
While you have the steering rack out, pull off the pinion gear cover and check the grease. Mine was hard as a rock, so it was time for a disassemble, clean and re-grease.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 08-27-2014, 11:28 AM
welding
Welding done today!
Old 08-30-2014, 07:45 PM
Old 08-30-2014, 07:46 PM
More today. Alloy block offs and getting ready paint
Old 08-31-2014, 04:23 PM
Shroud mods
Old 08-31-2014, 04:26 PM
jostein's Avatar
Nice. This post I must follow
951 1986
951 upgraded 1987
Old 08-31-2014, 05:05 PM
thank you, Primed and ready for seam sealer.
Old 09-01-2014, 06:26 PM
Time to tear into the rack and 993 console with alloy block off.
Old 09-03-2014, 02:09 PM
More cleaning today.
Old 09-06-2014, 07:49 PM
Some more progress today, cross brace PU points, 4" air filter hole.
Old 09-13-2014, 08:35 PM
