LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average.
update
Thank you for asking John
A few welding projects next.
The seat brackets are cut out, they are modified and need to be re-welded into a lower position.
Inboard seat belt harness brackets
Also adding the stronger rear stab bar brackets by Wevo.
Finish the fire wall off where the front oil tank intrudes into the pass side foot box.
Complete the sunroof delete thingy
Sand the entire car down to bare metal, finish truing of glass bumpers, then off to the powder coater and to paint after that.
So yea there is still some work left, but I'm making progress
Rod
"This Year ferrari's Ass is Mine"
Old 01-21-2015, 05:34 PM
Pictures!! Need more pictures!
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Ready for Paint
Old 01-22-2015, 08:43 AM
Old 01-27-2015, 04:08 PM
IMR-Merlin's Avatar
Wow,
How did I miss out on this epic build!! Bravo brother, keep up the good work!
Old 01-27-2015, 04:34 PM
Thank you, yea I have been following your build and really enjoyed it.
More metal work today, oil cooler ducting, seats brackets etc.
Anybody have a good idea for the center mounted seat belt p/u points?
Old 01-30-2015, 07:33 PM
power windows
Converting the power windows to hand crank. Driver side is missing the pin which hooks around the coil spring, i will need to get one of those?
Old 01-30-2015, 09:20 PM
Wer bremst verliert
JohnJL's Avatar
We are at about the same point. I put in my seatbelt brackets last week, I can snap a pic tomorrow. I essentially welded in 4 tabs so the harnesses are in double shear.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 01-30-2015, 09:40 PM
Ok cool, thank you.
Old 01-30-2015, 09:43 PM
IMR-Merlin's Avatar
I wonder how much weight you save from going from power to manual windows. I kept mine in because of my roll cage. I didn't want to do plexi sliders.
Old 01-31-2015, 04:44 AM
weights
I was thinking the same, When I get the little piece for hand crank to window regulator I will weight them against the power assembly.
Old 01-31-2015, 07:05 AM
Oil cooler
Messing about with the oil cooler ducting and oil tank surround.
Old 02-08-2015, 12:25 PM
IMR-Merlin's Avatar
Looking good man!! Nothing like making stuff on your own!
Old 02-08-2015, 01:34 PM
build it
Thanks, yea agreed, its nice doing your own stuff.
More today.
Old 02-12-2015, 04:44 PM
center belts
Old 02-12-2015, 04:49 PM
IMR-Merlin's Avatar
Were the factory center mounts in the seats?
Old 02-13-2015, 07:34 AM
belt p/u
Yea they where attached to the factory seat.
So made a chunk of metal contoured to fit inside the tunnel, drill, tap and weld in place.
Old 02-13-2015, 08:44 AM
fuel tank
Fuel tank cradle next.
Old 02-13-2015, 06:01 PM
IMR-Merlin's Avatar
I'll have to fab something up then.
Old 02-14-2015, 03:49 AM
Fantastic work. I'm surprised the Shaw IROC nose req'd that much work but the rear bumper was almost a perfect fit?
Old 02-14-2015, 04:37 AM
welding
I'm not bashing anyone Its just a personal thing. MA Shaw is good stuff.
The front bumper was not symmetrical to my car. I prefer tight gaps around the signal lights, which we will fill. The wheel well arch and angles from the front and back are not flowing with the body lines. On the rear bumper we extended the lip underneath the tail light housing which will fill that gap between the gasket material and tail light/bumper. Again truing up the wheel well arches and the view from the rear with the flow of the body.
I expected this with fiberglass and the hard work will be worth it, I hope
Still a tonne of work left to make them look good.
Old 02-15-2015, 02:31 PM
