I changed my boost spring (.9) out for a .7 bar one, my afrs are now fine all the way to 5600 rpm. I realize there is now less demand for fuel by doing this, but is there a chance while running 1 bar a few weeks ago for a day I could have damaged the over boost switch, or maybe the overboost relay is not doing what it should? The car is running almost normal right now with good afrs, (again only up to 5600 now). I'm not sure how this switch/relay work if it tapers off the fuel or if its a hard cut off when the switch is triggered...
1987 930 - 935 Tribute
1971 911T w/3.2 motor
Old 07-12-2014, 09:34 AM
It's very old technology so it's a hard cut by disconnecting the grounds to the two fuel pump relays. I don't think you'll hurt the overboost sensor on the manifold or intercooler by running over 1bar.
Old 07-12-2014, 09:41 AM
This is making me crazy, I took my WUR apart to make sure the diaphragm was okay - it was. I don't have the gauges to check my cis pressures but I will get them. I did the fuse panel mod today, checked and replaced most vac lines, checked intake manifold bolts, although wouldn't that give me a boost leak rather than a suction leak and cause me to run rich? I grounded the over boost cut off, same result. If my pressures were out I don't see how I would be getting perfect afrs from say 3000 rpm to 4500 rpm on boost full throttle, its just suddenly starts to go lean. It really seems like I have a fuel restriction somewhere... Also, I noted in another thread about a speed sensor under the driver seat... My 87 930 has nothing under the driver or passenger seat except the wires going to the harness for the seat itself...
Edit - also sprayed ether around intake manifold bolts, afr did not change. Made sure the test would work, checked by spraying some in the intake which richened up the afrs.
Old 07-13-2014, 09:41 AM
Turbo Hooligan
Clogged fuel injector? debris in the fuel head? all is pure speculation until you know where your control pressure is set.
www.d-zug.com
blog.d-zug.com
All these guys do is drive too fast, work on cars, chase ******* and drink.. really no fun at all...
Old 07-13-2014, 11:00 AM
6771911esses's Avatar
Vacuum advance of dizzy in order???? Bad coil or CD box? Sounds more ignition related now.
Old 07-14-2014, 01:38 AM
Tinkering Pays!!
mooney265's Avatar
Without CIS Gauges hooked up and a Mitey-Vac to simulate boost, you'd be hard-pressed to know how well your WUR is functioning...
If I didn't have: Adj WUR, CIS Gauges, Mitey-Vac and Wideband - - I'd be lost with my 930! Just a little adjustment makes a huge difference.
You need to be able to "simulate boost" on the WUR and see what's happening to your Boost-CP with Gauges hooked up...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 07-14-2014, 10:20 AM
Brought a Snap-On CIS kit home, the fittings are too big so now I'm stuck until mid week try and get some different ones. I did check the return line and I'm getting 1100 cc's in about 22-23 seconds so I'm good there. I made a video so you can see whats happening. Its less dramatic with the .7 bar spring in but I don't want to accidentally toast my motor either. A little more rich with the .7 bar in down low obviously, was running .9 bar springs and 1 bar occasionally.
https://www.youtube.com/watch?v=FhoEb9z6hEQ
Old 07-19-2014, 04:44 PM
