934.5 CIS setup
Thought this was an interesting CIS setup. Aluminum fuel head with two injectors per cylinder and ITB's, cone shape sensor plate, twin turbo, dual plug, three fuel pumps. Whats up with the injectors? Some special aluminum housing to enhance atomization, different injectors than the normal Bosch 009"s
Definitely Skunks Works Goin On Here.............................................. ....................... Car weight 1900 lbs, 600 hp @ 1.2bar and 900 @ 2 bar http://forums.pelicanparts.com/uploa...1404097888.jpghttp://forums.pelicanparts.com/uploa...1404097970.jpghttp://forums.pelicanparts.com/uploa...1404098034.jpghttp://forums.pelicanparts.com/uploa...1404098155.jpg |
wow
Oh my...
Gee wiz
Wow, for sure Übercool :-)
More info of the build? |
Don't know much else about this car except it was a Kremer car at one time, the owner now is John Seabrooke. There is a good youtube video Porsche 934.5 at SPA 2011. The team chose to run slicks and its raining and the car is really all over the place, bad decision as you will see. The car definitely has some serious power . I was hoping someone else might know something about this dual injector, ITB , CIS setup. I have not seen anything quite like this...................
http://forums.pelicanparts.com/uploa...1404187550.jpg
Oucheeee.......................................... ........... |
yes, can some shed some light on this awesome motor setup
| All times are GMT -8. The time now is 12:52 PM. |
